2012 Prius Breaths
Discussion in 'Gen 3 Prius Main Forum' started by 1IADocDave, Feb 15, 2025.
  1. 1IADocDave
    1IADocDave New Member
    SC Iowa
    Over 160K miles and I just noticed while the prius is idling the fuel filler is gasping either inhaling or exhaling at the gas cap. This happens at 8 second intervals while it is just idling. I've been a Prius owner since 2001 and have never heard anything like this.
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Have you read about the EVAP system?
  3. 1IADocDave
    SC Iowa
    Yes, I did not see any mention of the fuel filler cap gasping for air every 8 seconds while engine was running. Have you seen the happen?
  4. Brian1954
    Brian1954 Senior Member
    2,691
    1,076
    South Central PA, USA
    Do you have any warning lights on the dash?
    Have you checked for error codes.
  5. 1IADocDave
    SC Iowa
    No warning lights and no error codes however, it will take fuel VERY slowly. A guy could easily get frost bite trying to spoon feed the gas into this thing.
  6. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    Do you have a trusted local shop that you could take it to and have them perform a smoke test? Usually slow fueling is a bad charcoal canister but could be other things. Do you usually top off the tank after the first click?
