2012 Prius C 2 101500 miles dead battery
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Jonishere55, Jan 22, 2018.
  1. Jonishere55
    Jonishere55 New Member
    Spokane, wa
    Hey everyone I got a question for you so I have a 2012 Toyota Prius c what's 101500 miles I recently had the dealer service it with an oil change and 3 days later the car had a lot of warning signs so I took it to the dealer and they said it needed a new battery and I'm only at a hundred and 1,500 miles which is close to the end of the line 8 year 100,000 mile warranty.
    I noticed that around 80,000 miles to car was acting a little different power-wise so when I had a oil change I had them they said they would check things out but nothing turned up.
    I am trying to see if the dealer will fix it has a Goodwill repair but I'm not sure if that's going to happen any advice or suggestions? Anyone think I can somehow get Toyota to repair this under warranty still?
    I do plan on trading this in within 6 or 12 months.
    I'm not very handy so I don't think I can replace the battery myself they said two of the cells are going bad in the battery.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Trade it NOW. Should be able to get a deal on a left-over '17 if you can find any.
    How old it the 12 V battery ? It is almost always worth the $200 gamble to replace it first if it is the original.
    ESPECIALLY if the dealership is going ONLY by the trouble codes that they see.
    I highly doubt that they really KNOW the HV battery is bad because most likely that nobody in their shop knows how to use a voltmeter to test the individual cells.
    Dig out your warranty booklet and call the warranty help number.
    Be sure to mention the previous service visit where they couldn't find anything wrong.
    kenoarto likes this.
  3. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    The main cause of the traction battery "dying" is a difference in block resistance. There is no way to "check" the battery with a volt meter unless you remove and disassemble the battery to check the internal resistance of each module. To do this, you need to check the open circuit voltage of each module, and then again while applying a load to the module. The voltage difference divided by current equals resistance.
    I guess someone could pay a tech to do that level of testing to confirm the battery is "bad," but if the ECU says the battery needs changing, there's a 99.9% chance that it does, as the ECU has already done the internal resistance check. That's why the code was set.
    You can change the battery yourself. It's very easy and requires no programming. There is also a "core credit" on returned batteries. Here in Japan, I get $1,300 back, and that gets refunded to the customer when the credit is received.
    First thing i would do is to contact Toyota and ask about good will. At only a little over the mileage, there's a good chance they will replace it. That's early for a battery failure.
  4. Jonishere55
    Spokane, wa
    I'm currently in the process of talking to Toyota it's been really tough to get any supervisors on their National hotline I will keep you guys posted on what they decide to do hopefully they will do a Goodwill replacement because I feel like this was an exceptional case and the battery died way earlier than it should.
    Raytheeagle, bisco and masterC like this.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    At only 1500 mile over, you should almost certainly get a goodwill exception. We've seen folks here with many more miles get them. If nothing else, a good discount.
    GOOD LUCK!
  6. Jonishere55
    Spokane, wa
    Question worst case scenario Toyota doesn't pay for anything my dad is pretty handy and I was looking at YouTube videos on replacing the batteries in the 2012 Prius C does anyone have an instructional website or like a step-by-step instruction guide to replace the battery in a 2012 Prius C I saw one YouTube video that was pretty informative but it only got to the point of them uncovering and finding the battery it didn't go beyond that and installing the battery.
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    You should be able to call the service department at your (or another) local dealer and ask what the cost of a battery is.
    There will also be a $1,500ish refundable core fee .
    I'd be curious what they quote you.
  8. Jonishere55
    Spokane, wa
    So update Toyota gave me a 1k credit and also the dealer dropped the price. So it would normally be 4.6k but they got it down to 2.6k for the repair. Aftermarket I know I could get the repair for 1250 to 1500k add a non certified Toyota repair center.
    I do want to take this to to it corporate but the customer service supervisor of toyota corporate and not give me the number.
    Washington state has a 8 year 150000 mile warranty but the car was purchased in Florida which only has an 8 year 100000 mile warranty. So I am out of luck there.
    I'm hoping maybe I can contact Toyota corporate support and see if they can do any better.
  9. Jonishere55
    Spokane, wa
    Okay so so to update I have gotten an offer from Toyota customer support for $1,000 towards the repair and the dealer would take $1,000 off so the original bill would have been 4600 but they offered me 2600 for the repair. I was not happy with that offer so I decide to call corporate and see if I could get any additional funding for the repair of the car repair. They would not offer me any additional funding so I was very disappointed with that response I did get a quote from a third party for only about 1300 to $1,500 to repair and I ask corporate if they could apply the $1,000 that they are offering me towards that right there but they would not.
    Although I am happy that they did offer some assistance I'm still very disappointed about the the way that the whole situation was handled and how early my car battery failed that would advise anyone else be very careful when purchasing a Prius because the battery may fail sooner than what you are told by the salespeople. You may also be stuck with an older car and the battery could fail and you'll be stuck with the repair bill that's just about the price of the car so keep that in mind.
    I personally won't be purchasing a Toyota again.
  10. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    $4600 is too high for the cost of replacing an HV battery. Why not shop the repair to several dealers? Get competing bids.
  11. Jonishere55
    Spokane, wa
    They dropped the price to 3600 will see if other dealers can do better good idea
  12. Prodigyplace
    12,709
    11,847
    Central Virginia
    Users here have not had good experiences with repaired or remanufactured batteries. Some people have been able to find one from a low mileage wrecked car.
    If a dealer installs a Toyota battery it has a 3 year warranty. If they sell it and you install it yourself, it only has a 1 year warranty.
  13. kenoarto
    398
    Chicago, IL
    Remember the current full MSRP is $1950 for the part. It is being discounted to $1625 at several dealers. All the extra money is the cost of 1-2 hours of labor (any quote longer is gouging). $1000/hr is well...
  14. Prodigyplace
    12,709
    11,847
    Central Virginia
    I believe the battery price dropped on January 1 for Prius batteries. @ericbecky might know if Prius c was affected too.
  15. Sam Spade
    2,036
    1,024
    2017 Prius c
    Your previous post said 2600. Which is it ??
    I doubt that you will get it anywhere for less than that......for a NEW (not rebuilt) battery AND the labor.
    And a final personal comment: You can be "disappointed" all you want but if you buy ANY car and drive it a crap load of miles, you can easily "out run" the warranty and that is not the fault of the company making the car. The warrant is what it IS......not what you wish it was.
    priustexasbob likes this.
  16. kenoarto
    398
    Chicago, IL
  17. Prodigyplace
    12,709
    11,847
    Central Virginia
  18. kenoarto
    398
    Chicago, IL
    Prodigyplace likes this.
  19. Prodigyplace
    12,709
    11,847
    Central Virginia
  20. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Only Gen 2 packs are affected by price drop.
