2012 Prius C Aux 12V Battery - OEM, Best?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by MannySwol, Jul 3, 2017.
  1. MannySwol
    MannySwol Junior Member
    30
    I've tried to search in hopes there is a post recommending the "best" replacement parts... but kept running into regular Prius posts or those that go in circles about how to suspect a bad battery, etc.
    Question is simple...
    In replacing the Prius C 12v battery, is the best call to use the OEM? Or is there another specific model to use in lieu of this?
    Thanks
    52,847
    it's only a matter of opinion. no studies have been done. optima, if they make one for the c is quite popular, and there have been no negative reports on any specific brand.
    personally, if i ever have to replace a 12 volt, i'll go gem, but only because i've had such great success with the 3 i've had, not because there is any proof that it is better.
  3. MannySwol
    30
    The Optima site suggests they have no batteries for the 2012 Prius C... Are people doing mods of a specific model #?
    52,847
    not that i have read, that's why i said 'if'. you can also try auto parts stores, sears, walmart, amazon and batteries plus bulbs.
    i don't know if anyone makes one for the c though.
  5. DKTVAV
    DKTVAV Active Member
    510
    101
    A quick "battery" in the upper right search box.
  6. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Optima Batteries 8171-767 (DS46B24R) YellowTop Prius Battery
  7. RavMan
    RavMan New Member
    Australia
    Yep +1 in the optima shown above. Amazon do have a feature where you input your car details and it will show you parts that fit. Works for batterys aswell.
  8. XRinger
    XRinger Member
    201
    47
    Woburn, MA
    I've seen a 9171-767 YellowTop Model DS46B24R T (What does that 'T' mean)?
    battery for sell on Ebay ($166.99 w/ free shipping), and I'm wondering how different it is from the 81717-767 ?
    It's going to be another cold winter, and I'm thinking it's time to replace the OEM battery..
    Thanks,
    Rich
  9. Old Яomans
    Old Яomans New Member
    Homestead
    Hi guys. I worked as a manager at Auto Parts stores for 15 years. I just purchased a 2012 Prius C(3) with 51,000 miles. On most cars in South Florida, 12v batteries need changing every 2.5-3 years, even if they are AGM; though cars that have the battery away from the elements (BMW, Miata, etc.) tend to last much longer. When should I expect to change the 12v battery?
  10. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    If yours still has the OEM battery in it, I'd go ahead and swap it out. From what I've read, bad things happen to Prius' when the 12v battery dies.
  11. Kingsway
    Kingsway Active Member
    121
    119
    Cambridge, UK
    2014 Prius c
    Active
    Do a search for a thread called ' Fitting mobility 12volt AGM battery' by Britprius.
