2012 Prius c flooded help please
Discussion in 'Prius c Main Forum' started by Mike fig, Nov 25, 2024.
  1. Mike fig
    Mike fig New Member
    Orlando fl
    Good evening everyone! I lived in Florida and I have a 2012 Prius c the was salt water flooded from the storm. Vehicle was completely clean and dry out. Dash use to turn on but now nothing works. I took the main computer out clean it replaced all the fuses but no dash. My hazards works, head lights works but nothing else. I check all the fuses to make sure they are good.. any suggestions will be appreciated thank you all..
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,124
    6,980
    Texas Hill Country
    How high was the water in the car?
  3. whitrzac
    whitrzac Junior Member
    46
    madison
    Its done for.
    Saltwater damage isnt fixable.
  4. Mike fig
    Mike fig New Member
    Orlando fl
    It got to the top of the seat
  5. ChapmanF
    19,041
    I'd suggest a look at this thread, where posts 14 and 20 refer you to a Toyota TSB (the number is in post 20) all about quickly classifying your car as to the kinds of consequences you need to check for according to what areas the water occupied.
  6. rjparker
    11,124
    6,980
    Texas Hill Country
    That means the hybrid battery and battery ecu were submerged. The hybrid battery is under the rear seat.
    It very likely the can bus is down preventing modules from talking to each other. It would be useful to plug in a good scanner and determine if any of the ecus communicate.
    At the minimum you would have to remove any connector or module that was wet, clean it and hope for the best.
  7. ChapmanF
    19,041
    Any cheaper/faster fix than by following the TSB mentioned in #5 may prove disappointing or worse.
  8. BiomedO1
    BiomedO1 Senior Member
    4,632
    2,430
    Left Coast
    ^ Yep, and it sounds like your traction pack went under water. So fuses are most likely blown there too along with the emergency safety disconnect. If the traction battery ECU survived. You may want to check what kind of total voltage you've got in the pack, because you won't be able to crank the engine, if that's dead.
    Did you change the ATF? There's a vent cap that the salt water can get into, in the upper portions of the transmission. FYI
  9. rjparker
    11,124
    6,980
    Texas Hill Country
    I am afraid the whole experience is disappointing. Having lived near the coast after hurricanes, flooded cars are a problem longterm even if they are made functional again. To replace everything needed for reliability is not economically viable which is the reason insurance, if covered, will total the car.
    The tsb is free on the NTSB website:
    At minimum, you would have to remove any connector or module that was wet, clean it and hope for the best.
  10. Mike fig
    Mike fig New Member
    Orlando fl
    I replace the hybrid battery. But the thing is that I can’t even turn the car in accessory mode. I took the main ecu with the fuses under it out clean it replaced all the fuses. And nothing
  11. Mike fig
    Mike fig New Member
    Orlando fl
    Hybrid battery was replaced. 12v is new. Radio was working but once I took the main computer out to clean and replace the fuse the radio will not turn on. I can’t even turn on accessories mode on
  12. ChapmanF
    19,041
    There are a bunch of ECUs (don't know the exact count for a c, but probably over a dozen); whichever one you're thinking of as the 'main' one is far from the only one needing attention.
  13. Mike fig
    Mike fig New Member
    Orlando fl
    Okay thank you I will do a complete inspection clean and removal. If nothing comes up I will have to sell it for parts it only have 96 thousand miles. Excellent interior.
