2012 PRIUS C GPS
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Louisk, Apr 28, 2015.
  1. Louisk
    Louisk New Member
    Massachusetts
    The GPS screen is unreadable during the day. Any fixes??? Has anyone had any luck with replacement screens or GPS units from Toyota?
    52,776
    do you have the headlights off and the setting to day? some people make a cardboard hood to block the glare of the sun.
  3. Louisk
    Louisk New Member
    Massachusetts
    Yes the headlights are off and the setting is "day". Shouldn't need a cardboard cover on a GPS unit that costs about 5K to replace.
    52,776
    if it's the sun, thats the solution. if you can't see it in the shade, something is wrong.
  5. bisco
    52,776
    did i forget to say welcome? sorry!:)
  6. lsanch33
    lsanch33 New Member
    Orange County
    I have the same problem. I believe its the low resolution/brightness of Prius C touch screen which makes it difficult to see in bright day light.
  7. bisco
    52,776
    yes, it's been a problem across the toyota line forever. you can ask the dealer, but i don't think you'll be accommodated unless yours is defective.
  8. Louisk
    Louisk New Member
    Massachusetts
    I thought so. However there really is no excuse charging for a GPS device in a new car and the owner not being able to use it in day light. The only safe time to rely on GPS is at night with NO sun light what so ever. frustrating in that the car does what they said it would do and that is the very low maintenance and excellent MPG.
  9. Louisk
    Louisk New Member
    Massachusetts
    Also I have an uncanny rumble and vibration which I feel in the steering wheel, seat and floor. Vibration and rumble increase and decrease at same rate. Intermittent. Doesn't seem to have any effect on the vehicle. Not metal on metal. Toyota mechanic went out with me and acknowledged syndrome. Not heard of it before. Drove a late model prius c on the lot to compare and he sensed it in a new one. Said keep an eye on it. He checked factory alerts etc on it and found nothing. Went all over the car and found no problems. Howevr he said it felt like an engine mount.
  10. bisco
    52,776
    yes it has been frustrating for many. a lot of people mount a garmin or their phone in a strategic location. as for the vibration, there are a lot of complaints, but solutions are few and far between. good for you, taking a test drive in a new one. that's the best way to compare.
  11. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The only thing I found that helped at all was to set the contrast way down and the brightness up. But if the screen is in full sunlight nothing will improve the view.
