1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
(2012 Prius C) - Installed Coilovers need Adjustable sway bar end links [help]
Discussion in 'Prius c Accessories and Modifications' started by IshReleX, Apr 9, 2021.
  1. IshReleX
    IshReleX New Member
    Boston
    Just had a mechanic install Rev9 (NHP10) Hyper-Street II Coilover Kit and was told the factory sway bar end links are too long. Can someone assist on how I can go about getting the right universal adjustable sway bar end links? (GodSpeedProject?) As of right now I'm driving around with no end links, and lots of clunking going on in the front.
    Thank you!
  2. Daniel B.
    Daniel B. Junior Member
    Port Richey, FL
    This is odd, I actually just did this same install on my 2012 yesterday. I'm running no end links until I can order some. Looks like Amazon carries universal adjustment end links for about $70 I believe. It feels weird driving like that a little bit but I hope it's okay. Besides the end links, my problem was that the rear struts didn't fit in the bottom mount so either I have to modify them or call rev 9 and see what's going on. The metal bushing was too wide for mine.
    IshReleX likes this.
  3. IshReleX
    IshReleX New Member
    Boston
    I ended up buying SKU: SB-TR-180-10
    Hoping it fits, I'll get it in few days.
  4. Daniel B.
    Port Richey, FL
    I ended up ordering godspeed universal adjustable sway bar end links from Amazon. I hope they work. Now I have to figure out why the rear shocks don't fit and if rev 9 can help me.
  5. Daniel B.
    Port Richey, FL
    Hey did you ever get your sway bar end links in and installed?
  6. flatwerx
    flatwerx New Member
    Colorado
    Old post but did you get the end links in? How do you like the Rev9 setup?
  7. Daniel B.
    Port Richey, FL
    I did get the adjustable end links from Amazon. But after only 2 years with the setup, I had nothing but issues with the coilovers. Things never fit quite right, and then one of the rear struts blew and after contacting rev 9 directly, they refused to help me unless I had a mechanic install them and provided pictures. So about a month ago I replaced everything with factory struts and went with tein lowering springs and now I'm having other issues. So I have to take that apart again. In the end, you really do get what you pay for suspension wise and I would honestly go with a much better brand for coilovers if you're considering it. Like the tein street tech I think their called. You can get them usually for under a grand.
Loading...
