2012 Prius C ,Need help with wiring (wiring diagram would help)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Terror404, Apr 8, 2018.
  1. Terror404
    Terror404 Junior Member
    46
    houston, texas
    Hello, I have recently bought a car (12 Prius C) which was involved in an accident, not a big one, although left side cables were cut and I tried to restore them yesterday. I could not find 3-4 wires and I am having trouble finding their function.
    1. Light green wire coming from the main wires bundle, it is the thinnest cable of all, so I doubt it should either go to headlights or some other auxiliary unit
    2. 2-3 cables in in black with red line insulation, insulation is covered with aluminum foil from the inside, so I am really lost were should it go (I was suspecting it is radio cable because of foil,but doubt that).
    I will take some shots as soon as I get to the maintenance shop where the car is
    Any help would be appreciated,
    Also if anyone has a wiring diagram please throw that in her as well,
    Thanks
  2. qettyz
    qettyz Active Member
    181
    208
    Finland
    Pay few dollars to Toyota tech access for couple of hours and look official toyota wiring diagrams from there?
    Especially if you are doing wreck repair, there is plenty of other usefull documents also if needed.
    Raytheeagle likes this.
  3. Terror404
    46
    houston, texas
    where is that and how much should I pay?
  4. qettyz
    181
    208
    Finland
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    $15 for 2 days and you get all the info directly from the source:).
    Good luck with your project (y).
    qettyz likes this.
