2012 Prius C owners - What is your mileage and repairs to date.........
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by orenji, May 12, 2015.
  1. icspots
    icspots Junior Member
    2012 Pc4, 135,000 miles.
    Front/rear struts/shocks
    Front/rear brakes
    Various lightbulbs here and there
    Body work to front and rear left corners with headlight and tail light replacement (two different collisions)
    Stereo replaced with aftermarket when the OEM Navi unit crapped out
    Oil/filter, air filter, cabin air filter
    3 sets of tires
    Mostly just expected wear items given it was daily driven in and out of DC in heavy rush hour traffic for several years.
  2. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    Can I ask what brand and model you replaced the the stereo with?
  3. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    The stock 12V battery will most likely go 4 years, maybe even 5. When I work on these cars, the goal is to have them not break down, ever. So I change the aux battery at three years. This ensures that even the people who like to sit and run the audio for extended time won't experience a no-start due to a faulty battery.
    The bigger issue is people not changing the brake fluid on the recommended schedule. This almost guarantees premature failure of very expensive brake components.
  4. bilzhorse
    bilzhorse Junior Member
    23
    230K and my inverter just took a crap. That is the only thing that has ever been replaced other than routine maintenance. I got 220k out of the front brakes and the rears still have 70%
    iceman13 likes this.
  5. 2012PriusCOhio
    2012PriusCOhio New Member
    Ohio
    Sitting at 371,000. Used to drive over 1,000 per week for work. Have slowed down to 250-500 a month.
    Multiple Tire Changes. Spark plugs. Swapped out the Fan Blower. Had the brakes replaced once. Both my front doors lock actuators havent worked in a few years and I believe my 12v battery is on its last leg. Plan on fixing both of these issues this week.
    skayaks likes this.
  6. icspots
    I installed the Pioneer AVH-1550NEX. It happened to be on sale at the time, and was significantly less expensive than some of the other units which offered HD radio. It is not a CarPlay or android auto capable unit. I don’t drive that car often, and honestly I get annoyed when driving it.... when I’m listening to the radio and receive a text or an email the unit flips into Bluetooth mode (since my phone made a noise), then it sits there and makes me manually switch back to the radio. I don’t have that issue with other pioneer stereos I’ve used over the years, though those were all CarPlay stereos so maybe that’s the difference..... still it wasn’t an issue when connected via Bluetooth either.
  7. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    150k front brakes tires tranny flush plugs
  8. PriusII&C
    PriusII&C Active Member
    424
    142
    San Jose, California
    2012 Prius C model Two, 110K miles. Besides the regular maintenance items (oil, tires, coolant, ATF), just changed two burned rear light bulbs. With the car parking in the garage for the past 8 months due to the Covid-19 lockdown, I plan to do a brake fluid flush.
    Has anybody done a brake fluid change/bleed on model Two (no power button)? Just like to know how it is done and how it works out.
  9. cutter44
    cutter44 Member
    213
    MA
    Silver 2012 C Four with 149k miles on it (bought used with 34k).
    Outside of oil changes every 10k miles, I've done two transmission fluid changes (at 36k and at 147k), replaced a few bulbs, replaced wiper blades one or twice, cabin air filter a few times, replaced a couple of leaking taillights, and bought two sets of tires. New 12v battery at 145k miles. I consider those things routine maintenance.
    As for repairs, I had the passenger side lower control arm w/ball joint replaced at 108k miles (result of a pothole, I believe). And I had to have the charcoal canister assembly replaced twice; once at 51k miles, and again at 60k miles (I'm assuming they screwed up the first time because it's been fine since). Both replacements were done under warranty.
  10. fermuscolo
    fermuscolo Member
    53
    38
    2012 C One, Dark Gray 100.000 miles, Apart for regular maintenance started having problems with warning in the Hybrid system at 60.000, Dealer replaced Hybrid battery in warranty and problem persisted, after a month they discovered there where little cockroaches in the battery controller that where causing the errors, so new battery from 60.000, Changed 12v battery also at same time, at 80.000 the cooling fan failed so new fan and coolant, at 90.000 replaced struts, very bad streets in Puerto Rico.
    Im doing Uber with the car since 75.000 miles and car runs great.
  11. KevinD
    KevinD Junior Member
    NEPA
    2012 C Three with 120k miles, Parts replaced- Front brakes at 100K , Left rear wheel bearing replaced at 109K miles, 12 volt battery at 120K.
  12. Joe durt
    Joe durt New Member
    Virginia
    2012 prius c 3 194k
    -oil changes every 5k
    -12v battery swap at 190k (2022)
    -currently having proximity unlock issue (key fob buttons work, unlock proximity works, lights energize when nearby)
    -hybrid battery warning P0A80 intermittent (45% capacity, no high resistance, no cells appear to be dead)
    -looking into a charger/discharger to save my battery before it's too late (or is it already?)
    -3rd set of tires at 190k
    -all fluids swapped at 100k and 190k
  13. birdcatfish
    birdcatfish Junior Member
    NY
    2012 C - just bought used with 107K miles on it.
    It had a brake booster replacement,
    got new tires,
    new 12v battery,
    new front brakes - all before I bought it.
    Now, in my third week of owning it, I find it has a radiator leak - seams are coming apart in multiple places.
    Seller is going to replace radiator and some clamps.
  14. tankyuong
    1,555
    661
    Central MO
    223,000 P0A80 ordered a new traction battery, waiting on it due to back order from dealership, will replace it once it comes in
  15. davidbowen
    davidbowen Junior Member
    Baxley, GA
    2016 Prius c
    2016 with 84,000 on it
    SM-G996U ?
  16. Sonic_TH
    Sonic_TH Active Member
    570
    96
    Puerto Rico
    2016 Prius c
    Uhhh, another inverter failure, i don't know, i have already replaced a few things on mine, can't afford to replace and inverter.
  17. Campbell
    Campbell Junior Member
    Rochester, NY
    NCPriusC likes this.
  18. Campbell
    Rochester, NY
    I did the same thing - drilled a small hole in the back light to keep the water out. I am surprised that given this is such a problem there was never a recall. When I first went in, years ago, my car was under warranty. They accused me of having backed into something and perhaps creating a small crack...and refused to replace the bulb or the housing. Then years later, I keep seeing flooded tail lights in this forum and others... sigh
  19. NCPriusC
    NCPriusC Junior Member
    Upstate New York
    Hey class of 2012! I have a silver model 2 with 141k. Early on in the life of the car I towed it across a few states on a uhaul trailer with the rear tires rolling and it threw a bunch of lights on when I got in to back it down off the trailer... and the powersteering didn't work. They reset something at the dealership and all was fine. Turns out I should have disconnected the cables to the battery under the seat once on the trailer, so I did that on the return trip.
    New tires at ~49k Firestone, 91k Falken Sincera, 130k same
    At 70k I had to replace the 12v battery.
    Front brakes done at 98k
    New spark plugs and transmission fluid change 118k
    A wheel bearing 130k
    Around 116k I took it to my mechanic and dealership to diagnose an engine tickity tickity tappet sounds on a cold start up. And a low roughish groaning sound coming from the ICE when it is in slow speeds (30mph) changing from battery to ICE power etc. I don't notice the groaning all the time. Both shops didn't find or replicate the problem. Anyone have similar sounds and find a solution? I thought I saw tappet maintenance in the manual but the dealership mechanic told me it's not adjustable/ tweakable.
    Currently hearing a little muffler noise.
    Wondering what preventative maintenance I should be doing now? The maint log guide doesn't go past 120k miles.
    Perhaps brake fluid change, engine/Inverter coolant?
