2012 Prius C P0A80 Code After Battery Work
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Forde002, Aug 9, 2024.
  1. Forde002
    Forde002 Junior Member
    Missouri
    Hi!
    I am at a complete loss. I have dealt with this code for a while. I took my 2012 Prius C with 245,000 miles to have the battery reconditioned/cells replaced because of the P0A80 code, check hybrid battery warning, and abs/traction control lights. 6 cells were replaced because they were low/dead as well as the computer and relay pack. Bringing it home, we drove 200ish miles then the P0A80 code came back with “check Hybrid battery” warning came in again.
    Any advice? At this point I’m willing to try almost anything.
  2. PriusCamper
    PriusCamper Senior Member
    13,308
    5,379
    Pacific Northwest, USA
    The quality of a rebuilt battery pack is only as good as the person re-building it... And even the best rebuilder won't warranty for more than a few years, unless they're a really big operation that can absorb that loss... How much did you pay for your rebuild job?
  3. Leadfoot J. McCoalroller
    8,220
    7,720
    Pennsylvania
    2018 Prius c
    That is a game of whack-a-mole, and your mole just popped up from a different hole. This is a fairly common result for a module swap, though sometimes you get a lot more than 200 miles before it pops again.
    Somebody will need to gather data from the battery to determine whether the computer is unhappy with the new modules, or other original ones, or a combination of both. Either way, they are far enough out of sync to make the computer think the net result is a bad traction battery.
  4. Forde002
    Missouri
    It was about $800.
  5. bisco
    52,653
    is there are warranty? if they won't fix it for free, find someone else, but be aware that only a new battery is a long term solution.
    Brian1954 likes this.
  6. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    If there's no warranty from the company that did the work, you are pretty much on your own. My niece got a battery for her 2008 Camry from Green Bean Battery. It was around $1700.00 dollars and came with a 3 year warranty. 2 years and 10 months later the battery started having problems. Green Bean replaced it at no charge. Might be worth looking into. Keep in mind that even if you get your battery replaced by a Toyota dealer for somewhere in the $3500.00 range, they will only give you a 3 year warranty.
  7. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    Third planet from the Sun
    It makes sense to replace all the blocks yourself. Grab a kit from nuvant.com.
    It will cost $1,056.00 with a discount including shipping.
    The set includes 28 modules.
    4 modules will remain for stock.
