2012 Prius C P148F code
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by JackE, Jul 7, 2025.
  1. JackE
    JackE New Member
    North Carolina
    Yesterday when I was driving, I got the high temp (red thermometer) warning on my dash for about 3 seconds. When I scanned for engine codes, I got: P148F. What does this mean? Is it the inverter's water pump, or the engines? If I buy the parts, can I fix this myself?
    Thanks!
  2. JackE
    JackE New Member
    North Carolina
    Also, how do I check if my inverter water pump is working? Also also, should I replace the thermostat too?
  3. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    What is the level of the engine coolant in the reservoir? If the level is between the minimum and maximum level, it is time to replace the pump.
    The P148F code is for the engine water pump. Replace it ASAP. A replacement OEM pump is preferred. Cheap aftermarket pumps only last a short time. You do not want to do this job twice.
    JackE likes this.
  4. ChapmanF
    19,064
    P148F means the engine water pump is spinning faster than expected.
    Possible reasons could include that the plastic impeller has broken, so now it can spin without doing real work pumping water ... or that the coolant level is very low, so the pump can spin without real work pumping water.
    JackE and Brian1954 like this.
