2012 Prius C Three is NOT wired for heated mirrors
Discussion in 'Prius c Accessories and Modifications' started by Dodge Aries K, Apr 15, 2021.
  1. Dodge Aries K
    Dodge Aries K Junior Member
    48
    16
    Machesney Park, IL
    So, I was hoping to add heated mirrors to my 2012 Prius C Three. However, after pulling the door panel off, the door harness is NOT prewired for them. I'm not sure if the dash harness is (haven't looked into that yet) but I wanted to let people know because I tried searching for an answer and couldn't find one.
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Do you have pics of the harness? thanks
  3. ChapmanF
    19,009
    Any time you look in the wiring diagram (more info), you can see that certain wires will have numbered asterisks like (*1) or (*2) next to them, and somewhere on the page there will be a legend that explains which cars have those wires.
    Here's an example page. You can see some wiring alternatives down at the bottom, like the spiral cable having either a red wire to a fuse (in cars with Touch Tracer) or a black wire to the combination meter (in cars without), or the pink wire that either goes to the navigation receiver or the display-audio receiver, or goes to junction L85 in cars with a plain radio. You can see the explanatory legend up in the top right of the page.
