2012 Prius C Through P0A80 With Good Cells?
Discussion in 'Prius c Main Forum' started by JeffyPrius2012, Dec 5, 2020.
  1. JeffyPrius2012
    JeffyPrius2012 New Member
    Williamsburg VA
    2012 C Prius Four Red 120,899 Miles No Bad Cells? So I Went To Start My Car. I Got All The Lights On The Dash And Stop Hybrid Car In Safe Area. So I Pulled Out My Code Reader On My Computer VCI Techstream By Toyota. And Here Are The Codes I Got. I Checked The Hybrid Fan And It Was Dirty So I Cleaned It And Still Got P0A80. Could P0A80 Be Caused By U0101 Code? Let Me Know. Thanks Jeffy.
    P0A80 123 Replace Hybrid Battery Pack
    P3000 123 HV Battery Malfunction
    C1259 58 150 HV System Regenerative Malfunction
    C1310 51 156 Malfunction In HV System
    U0101 Lost Communication With Transmission Control Module
    Auxiliary Battery 12.71 Off 14.60 On
    BB1 17.10
    BB2 17.00
    BB2 17.10
    BB3 17.15
    BB4 17.02
    BB5 17.11
    BB6 17.09
    BB7 17.14
    BB8 17.04
    BB9 17.15
    BB10 16.99
    #1 JeffyPrius2012, Dec 5, 2020
  2. JeffyPrius2012
    Williamsburg VA
  3. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    If the 12v battery voltage is low you might get any number of computer fault codes. When did you last replaced it? (Or charged it ?)
    *Pepboys has a larger capacity battery for a lower price tham Toyota that only. requires the bracket to be bent.
    If worse case and you need to replace the traction battery you have options.
    Check my threads. I have replace the 12v lead acid and the traction battery and the help members gave me plus my descriptions might be valuable.
    Robert
    #3 RobAustin, Dec 6, 2020
  4. PriusWave
    PriusWave New Member
    16
    Los Angeles
    Jump the 12V and see if it starts normally with no codes. After you jump it you may still have the check hybrid code. Reset it.
  5. JeffyPrius2012
    Williamsburg VA
    It tested good the 12V it was at 12.71 off and 14.60 on it was never replaced before so why P0A80 With good cells. I cleaned the fan In back. What is the U0101 code anyway? I never took the traction battery out just the cooling fan and clean it.
    #5 JeffyPrius2012, Dec 6, 2020
  6. JeffyPrius2012
    Williamsburg VA
    Yep it still there
  7. bisco
    52,849
    lost communication with the tranny ecu. any chance of corrosion or rodents?
  8. JeffyPrius2012
    Williamsburg VA
    don’t know where is that located
  9. bisco
    52,849
    inside the tranny maybe? check the service manual
