2012 Prius C Traction Issue
Discussion in 'Prime Technical Discussion' started by gazoo6045, Aug 17, 2020.
  1. gazoo6045
    gazoo6045 Junior Member
    covina
    my traction light kept coming on off rapidly for the last couple of weeks when i made turns. now i made a turn and has stayed on. wont turn off. has anyone seen this?
    52,880
    sounds like a bad wheel sensor or bearing.
    are all the tires and pressures the same?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yep. Sounds like a wheel speed sensor going bad.
    Probably on one of the front wheels.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    @bisco offers a good probability. Have you tried asking in the Prius c forum? This is the Prius Prime forum. The systems should be similar though.
