2012 Prius C voltage spikes
Discussion in 'Prius c Technical Discussion' started by BrotherTeresa, Mar 26, 2023.
  1. BrotherTeresa
    BrotherTeresa Junior Member
    Ohio
    https://youtube.com/shorts/RRzNRz6cOLY?feature=share
    Attached a video of my results from Dr. Prius. Are voltage spikes in the 19v area normal under hard braking? Also was a little concerned when the pack voltage spiked too. It shows I have 56 percent life left on the battery, I’m assuming these results confirm it’s about time to replace?
    52,858
    idk but i'm curious, how many miles on her?
  3. BrotherTeresa
    Ohio
    104k
    52,858
    that's about the average replacement years and mileage from what i've read.
    still, i wouldn't do anything but research until you get trouble lights. it could last for years.
  5. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    What is the voltage difference when the state of charge is low? right before the ICE turns on.
