2012 Prius C won’t start
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by dbv8787, May 9, 2019.
  1. dbv8787
    dbv8787 Junior Member
    47
    cali
    Today I started my 2012 Prius C and the LCD lights etc started normally, but the engine won’t start. I pressed the start button again but it won’t turn off either. It sporadically displays things on the lcd but engine won’t turn off. After a few tries I’m able to turn off car.
    If this were a battery issue wouldn’t it not turn on at all? Is something on the fritz? Any ideas?
  2. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    First thing you should do is check the 12v battery and go from there. Some people have reported weird behavior like this when the 12v battery is failing.
    ztanos, orenji, dbv8787 and 1 other person like this.
    52,803
    start with the 12v health. how many miles on her?
    dbv8787 and iceman13 like this.
  4. dbv8787
    47
    cali
    About 65K. I don’t think I have the right tools to check the battery, is this something anyone can do?
  5. dbv8787
    47
    cali
    Not sure how to check, do I need a special tool like a voltmeter to check?
  6. bisco
    52,803
    yes, voltmeter, pretty cheap. check it in the morning before turning anything on.
    you can get a freebie with load test at an auto parts store.
    if it is original, you could just replace it. but that may not cure the problem.
    ztanos and iceman13 like this.
  7. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Yes, you need a voltmeter. A new battery is 12.7 volts. Below 12v you need to change it for a new one. Is it the original battery? Since 2012?
  8. bisco
    52,803
  9. dbv8787
    47
    cali
    Yes, original battery. I brought it to Toyota dealership for a regular checkup and it came back fine. I think I have a voltmeter somewhere. Will a cheap one work? Is there any danger of blowing myself up if I connect it wrong?
  10. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    No, you won’t blow yourself up . Just don’t make contact between the battery terminals and you will be fine.
  11. dbv8787
    47
    cali
    Can I just call AAA and have them check and replace battery if needed? I did that for my Mazda several years ago. Or do they not do Prius batteries?
    orenji likes this.
  12. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Well, I can’t assure you that they can but if they did it with your Mazda I don’t see why they wouldn’t do it with the Prius. Just tell them what car it is when you call. They can at least check the voltage for sure.
  13. bisco
    52,803
    depends on the driver. just make sure they don't crosspollenize the connections. can be expensive in a prius
    iceman13 likes this.
  14. dbv8787
    47
    cali
    Well, if they mess up then I suppose they’d be responsible for fixing/replacing it. Thanks for the tips.
    ztanos and orenji like this.
  15. pashko90
    pashko90 Junior Member
    47
    28
    SoCal
    Where are you located at? I can help you in LA or OC. 5624999091 text pls
    ztanos likes this.
  16. dbv8787
    47
    cali
    I ended up calling a hybrid battery service, he asked me how long I had the car/battery for, when I said 2012/65k, he said to buy a battery and bring it to him and he’ll replace it for $35. I went to O’Reilly and they said they don’t carry Prius C 12v batteries and the Prius battery is not the same. So I called the guy back and he said to buy the regular Prius one. When he went to install it the size was slightly different but he said it would fit. However the metal frame needed to be cut since the Prius battery was slightly longer. He tested the old battery and it looked good but he said that’s because I was driving around. He said I can get it tested another day for free at Autozone or something.
    iceman13 and bisco like this.
  17. bisco
    52,803
    well done!(y) did the engine start?
  18. dbv8787
    47
    cali
    It did, but it also started several times today before the swap as well. I think 7+ years is enough for a 12v battery such that these wacky things happen. I’ll know for sure by summertime whether it really was a battery issue I suppose. Thanks for the feedback everyone.
