2012 Prius - CEL P0301 Cylinder 1 misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by EchoToPrius, Jul 25, 2024.
  1. EchoToPrius
    EchoToPrius Junior Member
    My mechanic performed a compression test and confirmed it was the head gasket. They performed a head gasket sealer which turned off the CEL for one day. The prius still knocks at start and will misfire while accelerating.
    I am looking to make this car last as long as possible in it's current state. I do not want to put anymore money into it. I will only be using it for my daily work commute of 26 miles.
    I have read that taking off both coolant caps and running high heat at start up will help with the drive.
    Is there anything else you can recommend?
  2. Mendel Leisk
    42,331
    Flush out the sealer and replace head gasket.
    Never mind; you don't want to spend any more on it.
    Just postmortem:
    What's the miles?
    EGR system ever cleaned?
  3. EchoToPrius
    324,000. Full EGR assembly was replaced 1 year ago. Spark plugs in March. New tires in December.
    Now you can see why I don't want to spend anymore money on it and want to make it last as long as possible in it's current condition for my daily 26 mile round trip work commute.
  4. EchoToPrius
    To replace the head gasket, the lowest quote I got, was still more than what the car is worth.
  5. Brian1954
    Brian1954 Senior Member
    2,671
    1,069
    South Central PA, USA
    Run it until a piston rod breaks and puts a hole thru the block and leaves you stranded during your commute.
  6. EchoToPrius
    Now that is solid advice!
  7. ETC(SS)
    7,535
    AAA membership.
    Brian1954 likes this.
  8. EchoToPrius
    I have good sam roadside assistance.
    I also plan on trying to drive in EV mode as much as possible and when not in EV mode I plan on keeping the RPM low.
  9. bisco
    52,832
    ev mode just makes the engine run more, but maybe at less harmful rpm's, idk.
    keep the a/c off if you can stand it.
  10. EchoToPrius
    I definitely plan on not running the AC.
