2012 Prius - clock loses time
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hasnain Panju, Dec 4, 2012.
  1. Hasnain Panju
    Hasnain Panju Junior Member
    I have a 2012 Prius base model. The dash clock loses almost 3-4 minutes a day. Its still under warranty so I'll likely take it into the dealer and get it checked out..anyone else have this issue ?
    The only thing "different" is I have a Garmin HD Bluetooth connector (which streams engine stats like the Scanguage does to my GPS unit) hooked up to the OBDII port..but that *should* not cause any issues I think.
    radiocycle and Bob Hahn like this.
  2. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    I have the same problem of the clock losing 3-4 min / day in my Plug-In Advanced.
    I got the car 8 months ago. The slow clock has been an issue from day one.
    I'd rather the clock be slow, than fast. It is easier to advance it a few min.
    Bob Hahn and Hasnain Panju like this.
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Wow! Mine loses 1 min every 2 weeks or so and I thought it was bad!
    Did their quartz crystal get affected by the radiation from Fukoshima?
    radiocycle and Hasnain Panju like this.
  4. Hasnain Panju
    You are right..better slow than fast lol...I'll take it into the shop and see what Toyota says. Glad I'm not alone :-D
    radiocycle likes this.
  5. Hasnain Panju
    Hope not !..then we have bigger problems on our hand than slow clocks..hehe
  6. jbrad4
    474
    148
    Rowlett, TX
    I mis-spoke earlier. I'm only losing 3-4 secs. per day - not minutes.
    HTCEVOV4G ? 2
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    4 seconds a day works out to 56 seconds every two weeks. This is on par with mine.
    Does OP mean 3-4 mins a day? If so, it is ridiculous and I will definitely get it checked out.
  8. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    My clock runs fast - gaining about a minute per month.
  9. jameszhc
    jameszhc Junior Member
    China
    You are not alone. My G III also goes 3 to 4 mins lower a day - when I have my external HUD hooked on the OBD. The problem goes away when I have it unpluged. Still didn't figure out why is that. Did you get any feedback from your dealer? Thanks.
    Bob Hahn likes this.
  10. Hasnain Panju
    I verified this -- when I disconnected my Garmin ECOroute HD, the clock was keeping time perfectly -- when I connect it, the clock loses time. I have not approached the dealer, I know what they are going to say :) -- don't connect it ! But I love my Garmin HD so I just make sure I push the minute button every couple of days to keep the time relatively accurate.
  11. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    Do you know what kind of protocol is used for communication via your OBDII plug? It can be some bus timing discrepancy. My adapter uses the ISO 15765-4 11bit 500kbits and I don't experience any issues with car's clock, just few seconds per week.
  12. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Very interesting, because I recently had to bump my clock up a few minutes, I thought it was odd. And guess what I too have the Garmin ecoroute. Mine is a Prius IV 2013
  13. Mendel Leisk
    42,101
    We have an older Garmin, and afaik the clock is about as accurate as it can get. Adjust it for daylight saving to standard, that's the only time.
  14. phvdriv3r
    phvdriv3r Defender of the Glass - Lemon-ed a 2012 PHV
    127
    30
    My 2012 Plug-In loses on average about 1 minute a week lately... it seems to have increased since the weather got colder... If this was a regular PC, that would be a huge problem... I just wonder if this has other implications other than just an annoyance to owners.
  15. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    Amd I thought it was just my car. I have a PiP and the clock loses about a minute every two weeks.
  16. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    My clock runs fast to the tune of about a minute per month. I often have to wait for the hourly news to come on and then hit the "00" button to reset it to the nearest hour. Prefer that than hitting the minute button 59 times.
  17. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Not sure what causes this, but the Garmin is the reason for the clock time issue. I don't understand it,so I don't have a solution
  18. Jumpjet
    Jumpjet Member
    77
    25
    I have the same issue losing 3 minutes a day running Torque with the obd2 plugged in. What I did to get around the issue is I founda pprogram that will automatically close the Bluetooth connection when I turn off the car and turn it back on when power is restored without having to remove the obd2 device.
  19. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Anyone know what the root cause of this is?
  20. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    The Prius is not at fault. The root cause is time itself is out of calibration, it is moving too fast. The Prius itself is correct. :D
