2012 Prius - clock loses time
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hasnain Panju, Dec 4, 2012.
  1. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Hmmmm hadn't thought of that
  2. El Dobro
    El Dobro A Member
    7,102
    3,280
    Yes, the world is out of sync with our Prii. :D
  3. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Hmm.. There was a discussion about this in xkcd, of all places. What I remember, though, is that there are a number of time standards. For lack of a better term, there's Universal Coordinated Time; that's the one with leap seconds that make up for the Earth slowing down. Then, there's GPS time. My understanding is that GPS time is fixed, based upon some date in the 1980s, and does not have leap seconds. Which means by now that GPS "noon" is not too close to what UCT calls noon. Switching back and forth from the Garmin may be causing the local clock to skew around as a guess.
    I'm running a stand-alone TomTom. I note that at one point in the setup of this thing it had me set the local time. Now, at the time I thought that was mildly funny, since all those satellites had to have really accurate time clocks, so why not get the time of day from them? But if they really have been free-running up there since the 80's, it's a good bet that they're off by a few minutes by now.
    Finally: Part of my work life is playing with the plesiochronous clocks in the telecom network. Let's see, we've had complaints about 7 seconds per day. That works out to be 7/(24*60*60) =81 parts per million offset. Your basic, pretty blamed cheap (a couple bucks) quartz oscillator is typically +-50 ppm in accuracy over temperature, voltage, and aging, so it looks like the clock manufacturers are using something pretty cheap in the Prius.
    KBeck
  4. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Seems to me it's some kind of voltage drop, from having the OBDII being plugged in. I don't have an electrical print to figure it out. Need to see if the clock is seeing a voltage drop with the OBDII plugged in
  5. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    The Torque app itself can do this task. Settings-dash installation-airplane mode when no power.
  6. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Odd. Usually one takes in 12V and reduces same to 5V, 3.3V, or whatever the VCC du jour is on the electronics in question. And those "reductions" are done with linear or switcher regulators which have very good output regulation. And standalone oscillator devices are further supposed to be invariant in frequency with voltage variation.
    If there's that much variation - well, very, very, very cheap oscillators.
    KBeck
  7. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    I'm using my Garmin ecoroute to monitor RPM, engine temp, engine load, etc. the Garmin goes into a S/D mode however I don't know what the OBD dongle does.
  8. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    The root problem is in the use of the obdii port. It appears that unless there is a way to turn off or unplug the connection, which is very inconvenient I'll just need to bump up the clock minutes ever other day.
  9. El Dobro
    El Dobro A Member
    7,102
    3,280
    I haven't used the port yet, but the clock still loses about a munute a week.
  10. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Hmmm that's interesting? My wife has a 12 and I didn't notice any time loss. I'm curious do you have any devices in any outlets?
  11. El Dobro
    El Dobro A Member
    7,102
    3,280
    None at all.
  12. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    well hmmmmm, i wonder if there is a way to fix it with software. it just seems odd. not a big deal but it is annoying.
  13. HybridSpin
    HybridSpin Junior Member
    Could this be the same software malfunction that causes the speedometer to read fast and the MPG reading to be off as well?
  14. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    There hasn't been much chatter on this topic. Probably due to most folks aren't using a GPS or a scan gauge or some other obd2 device
  15. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    Actually, only 16 seconds separate UTC from GPS time. Closer than most any other randomly-selected pair of clocks in the average person's house, I'm sure. :)
  16. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Anyone ask a dealer about this issue?
  17. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    My clock can lose up to 1 or 2 minutes a day. Think this is a warranty issue?
  18. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Me, I'd think so. Tell them and find out. The worst they can say is "no". And, if you're lucky, they'll tell you the threshold of "how for out before repair".
    KBeck.
