2012 Prius DEATH RATTLE persists AFTER replacing EGR valve etc.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sapnetjr, May 5, 2018.
  1. evilchargerfan
    evilchargerfan Junior Member
    24
    42
    San Diego
    the Ct200h is indeed, a "turd gen" (giggle) part for part. my Honda Fit does well on the highway, but scooting around town with stop lights and traffic, it is most def not as good on mpg
    I wont even get started with my nightmare, dealing with Lexus Corporate and trying to convince them that my issue deserved the same tsb that Prius owners received. I was told "your VIN does not pull up any recalls or qualify for any tsb" .... SMH.
    As you guys get more of these death rattle's, please feel free to point a few people towards my thread, so they can avoid certain things (like replacing maf, coil packs) and not over spend unnecessarily
    m.wynn likes this.
  2. Mendel Leisk
    41,512
    That's a manifestation of the disease of "professionalism". Another example: "that's not my file".
    evilchargerfan and m.wynn like this.
  3. Eric Concepcion
    Eric Concepcion New Member
    Pennsylvania
    Going through the same issue, new coil packs and issue persist. Gone through the EGR system and intake. I've poured techron in my last tank, and I'm changing the transmission fluid tomorrow 7/5/19. I will post if anything changes. My Prius is worse with subtle acceleration, if I use power mode and slam the pedal it doesn't happen at all. I did find one post that stated the car needed to be driven hard after carbon cleaning. I also Seafoamed the intake system.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    How many miles on your Prius?
    Is the coolant level stable?
    Any dash lights?
    Installed an oil catch can?
    Good luck and keep us posted (y).
    mjoo likes this.
  5. Mendel Leisk
    41,512
    Try leak-down test?
  6. strategy400
    strategy400 New Member
    25
    Victorville, CA.
    2015 Prius c
    Check for combustion gasses in the radiator with this kit. Also, the "best" way to replace the headgasket is by decking the block and resurfacing the head. Which would mean stripping the block down. In case anyone happens across this old thread.
    Robert Holt likes this.
  7. Mendel Leisk
    41,512
    Doesn't hurt to check with a machinist's straight-edge and feeler gauges first. In particular with the block, since it's still installed, not necessarily going to a machine shop.
    SFO and Robert Holt like this.
  8. ChapmanF
    18,249
    My old Gen 1 developed such a rattle at 198,000 miles. Never found the cause, and its 1NZ engine is different from third gen's 2ZR in several ways. Sold the car at 23x,000-something. I guess it wouldn't surprise me if there was more than one way "the" issue could be caused.
  9. David Sell
    David Sell Junior Member
    Simi Valley, CA
    I very recently changed my spark plugs on my 2011 Prius. It had been doing the death rattle periodically for months prior. After the plug change it seemed to run better, then last week I got the P0303 code. After reading these forums extensively I checked my coolant overflow and noticed it islow. Hadn't checked it regularly. Should I suspect a bad plug first? Car has 226k.
  10. Mendel Leisk
    41,512
    Has the EGR and intake manifold ever been cleaned?
    pjksr02 likes this.
  11. David Sell
    Simi Valley, CA
    Not to my knowledge.
  12. Mendel Leisk
    41,512
    Coolant level in reservoir stable?
  13. David Sell
    Simi Valley, CA
    Haven't been monitoring regularly but noticed it is about a 1/2" below the low line.
  14. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    That’s pretty low
  15. Mendel Leisk
    41,512
    Watch it for a week or two, see if it's stable. If you've got Toyota Super Long Life Coolant on hand, I'd top it up to the top line for starters.
  16. Pdaddy
    Pdaddy Member
    160
    49
    Did you find out what was wrong?
    SM-G960U ?
  17. Perl1947
    Perl1947 Junior Member
    46
    Israel
    Same happened to me .
    It was the egr rubber hose that I pulled by mistake. After inserting it, the car run very good.
  18. Perl1947
    46
    Israel
    I have installed occ , it's saves the engine from burning oil.
  19. Mendel Leisk
    41,512
    If piston rings are gumming up it’ll still burn oil. OCC might help some though.
  20. Priustech87
    Priustech87 Junior Member
    Houston Tx
    Sadly that is a blown head gasket. I will show you photo of what a blown head gasket look like. One photo is what a good engine should look like with no trace of oil seeping from the head gasket and other one the one with blown head gasket where you can trace of oil has seeped out of head gasket. I took this photo in my shop where a customer complained her car would sometimes misfire. Dealer could not find the problem but obviously failed to do a visual IMG_1344.jpeg IMG_1343.jpeg
