2012 Prius - Engine Overheating
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Moonlite, Sep 2, 2017.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
  2. Moonlite
    Moonlite Junior Member
    CA
    If I'm reading the ECT from my scanner connected to the ECU, then doesn't that mean the ECT sensor is working and it is registering properly with the ECU? Or is there a couple of separate circuits in the single sensor unit?
    Perhaps I should just replace the ECT sensor since I'm due for a coolant replacement anyways.
  3. NutzAboutBolts
    1,756
    1,789
    Bay Area
    If you turn on the engine, can you read the ECT temperature through your scanner?
  4. Mendel Leisk
    42,352
    Here's thermostat replacement instruction. Someone mentioned heating up old and new thermostats should be done in coolant? Seemed a little far-fetched to me, and the manual just says use water too.
    Still, I think when thermostats fail, it causes excess cooling??
    Addendum #1: attached Engine Temperature Coolant Sensor info.
    Addendum #2: attached Engine Water Pump info.
    #24 Mendel Leisk, Sep 3, 2017
  5. Moonlite
    CA
    Yes, I can read live data from 39 parameters. ECT is one of them. That is how I got the correlated temp events I listed in post #10.
    Raytheeagle likes this.
  6. NutzAboutBolts
    1,756
    1,789
    Bay Area
    It depends if the thermostats is stuck closed or open, usually the thermostats when it's bad is stuck closed, which causes the engine to overheat.
  7. NutzAboutBolts
    1,756
    1,789
    Bay Area
    @Mendel Leisk do you mind attaching the file on how to test the ECT sensor. I'm not at home right now lol
  8. Mendel Leisk
    42,352
    Yeah I think you're right, I'm muddled: out-of-the-box the thermostat would be closed, it would be easy to fail thus. Funny, mine was the other way round though, it would open too soon, when I "raced" it with the new one. Also, brittle/fraying gasket made it half-open all the time.
    Yeah think it's there now, misnamed as Engine Temperature Coolant sensor.
  9. Moonlite
    CA
    Thanks for the manual section for the ECT sensor replacement.
    Thermostats can fail in the open or closed position.
  10. Moonlite
    CA
    Well, the overheating is definitely related to the two radiator cooling fans not coming on. While slowly driving around in the hills, I let it get up to 204F. I then pulled over to see what the fans were doing. They were still. I turned on the AC, the fans kicked in and the temp went down.
    I checked all the fuses, in the engine bay and cabin fuse boxes, and all are good. I also swapped the two identical fan #1 and fan #3 relays in the engine bay fuse box nothing changed.
    Where can I get a good wiring diagram to trace out the two radiator cooling fan circuits?
  11. NutzAboutBolts
    1,756
    1,789
    Bay Area
    The fan works, I would check the ECT sensor. The ECT sensor turns on the fan when the engine coolant is hot in the engine, which prevents it from overheating.
    There is 2 way to turn on the fan, one is manually through the AC control and the other is the ECU. The ECU receives all the signal from sensors and their devices from the engine, which will trigger the relays to turn on and off.
    Like I've said, the relays and fans work, it might be the sensors not working properly by detecting the the engine coolant temp to turn the radiator fans on.
    Have you checked the ECT sensor?
  12. Moonlite
    CA
    I assumed the ECT sensor (the one on top of the engine toward the driver side) is working because I'm reading the ECT temp with my OBDII scanner. Could there be a second sensor?
  13. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Nope, that's the only one.
  14. ChapmanF
    19,027
    For a long time I've wondered how common it could be for a thermostat to stick closed, considering what opens it is a blob of wax that will expand when heated ... seems like one of those "what happens when an immovable object meets an irresistible force" kind of situations. (I've noticed I actually have two home appliances where the engineers have used "wax motors" to open the door locks ... basically the same principle as the thermostat, a blob of wax with a heat coil around it, works the door lock when it expands. When the control circuit turns on that heat coil, it pretty much knows that lock will open, no matter how neglected, wet, and rusty it might get.)
    But it seems like I found the answer on this web page by Stant: "A thermostat will fail 'closed' if the wax element has been damaged by overheating ..." Aha, that explains it. Let your engine get good and overheated (for some, non-thermostat, original reason), thermostat opens to full travel, wax still needs to expand, bursts its containment, result dead thermostat, and future overheating even after the real original cause gets fixed.
    Therefore, they suggest replacing the thermostat any time an engine has severely overheated. Makes sense now.
    -Chap
  15. Nadeem
    Nadeem New Member
    Pakistan
    2011 Prius Alpha
    I was driving my Prius Alpha 2016, on hill side. when the speed is over 30 KM my car gives no problem, but when speed is below 20 KM after each 3 KM it display message that "Hybire system is overheated". I have to stop my car and turn off engine and wait for 30 mins them again after 3 KM on speed of 10 to 15 KM per hr same message appear.
    my car is only 30000 KM driven and new. Give no problem if speed above 30 KM/H but when is rough and hill side it gie this message can some kindly guide me what is the problem . or i change my vehicle ?
  16. Mendel Leisk
    42,352
    If you're getting a warning there should be codes stored. Get dealership to check codes? Very new vehicle perhaps no charge for diagnostic, or under $100 (US) at most?
    It could be clogging hybrid battery fan, though not sure. If you're handy this is something you could check yourself.
  17. Stephen J Nesbitt
    Stephen J Nesbitt New Member
    Need help with 2010 Prius, 2 months ago it threw P261b code. Changed water pump, cleared codes and the car ran fine for 2 months. Then it threw P261b, P261C. Bought SZ-TONDA. Had trouble getting the device to read ECU. Once we updated the computer and got access to ECU. I did a health check on all ECU's , the following Engine & ECT section reported that the calibration 34715200 and update "YES" and ABS/VSC/TRAC - calibration F152647106 - Yes. Cleared DTC, Engine Water Pump 0 RPM, Coolant Temp 180. I activated Water Pump manually and it stated speed was 3000 RPM in dialog box and speed requested was 3150 actual was 3950 RPM.
    Has anyone seen these symptoms? Help would be appreciated
  18. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Please start your own thread. You aren't going to get much exposure on a thread started over 2 years ago.
  19. Mendel Leisk
    42,352
    Posting to an existing thread bumps it to the top of the list in "new posts", technically the same "exposure". That said, it probably is best to start afresh. But here we are, just keep going?
  20. iskoos
    415
    254
    Orlando, FL
    @Mendel Leisk
    Thanks for attaching those pdf documents. I copied them to my Prius folder already. You never know when you would need them.
    I had a thermostat failure on my 2002 E46 many years ago. It got stuck open. Coolant temps weren't getting over 160-165F. I got a CEL and replaced the thermostat. The thermostat on E46 using wax to open close but it also has a heater element for the ECU to open close it when necessary.
