2012 prius engine replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by acp380, May 6, 2017.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Hope you feel better soon.
    Does it get you out of any "honey do's"?
    Still allows for posting it looks like(y).
    m.wynn likes this.
    52,789
    thanks! it gets me out of everything, and i get room service. still not worth it though.:p
    m.wynn and Raytheeagle like this.
  3. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Hopefully that's a short term answer and not long term answer ;).
    If not, I'll file that away for future reference.
    m.wynn and bisco like this.
    52,789
    yes. let's just say we won't be moving to cali this summer.:(
    Raytheeagle likes this.
  5. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Hopefully last weekends "house hunters" marathon served at least as good foundation building for the long term future;).
  6. bisco
    52,789
    temecula looked interesting.
  7. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Based on moving from Taxachussetts, you should easily be able to find something in your range there.
    Your close to a lot of activities there(y).
  8. acp380
    acp380 Member
    71
    61
    US
    Sorry guys. I told yall I wasn't very good at documenting the work I do. Also I've only been able to work on this thing like 5 minutes a week it seems. Finally got this thing back together. The engine came out the bottom very easily and went back in pretty easy.. The only mistake I made was disconnecting the steering linkage closer to the engine.I just took the bolt out and assumed it would slide apart. I should have done it from on the inside. The shaft is telescoping and it would have been a breeze to separate. But instead when I dropped the cradle it didnt separate and it ripped the 2 telescoping halves apart ruining the shaft. I had to find another on eBay. I think I paid 60$. Also I noticed the heat recovery valve on the exhaust was cracked where the nipple was welded into the body. Looks like it took a hit. That explains the coolant loss I was experiencing. I figured it was a bad head gasket and water was going out the tail pipe(which it was in the form of vapor). luckily my neighbor is a tig welder. I assume it's 304 stainless. He' going to weld it up tomorrow. Once that bad boy is back on I can fill up the coolant and see if she fires up. I do have a concern. When building an engine they are pre-lubed for the initial start up so the bearings aren't dry for the second it takes for the oil to fill all of the passage ways. Well this isn't a newly built engine but it has been sitting for at least 6 months without oil in it. Is there enough residual oil for the start up? Is there a way to crank the motor without it firing to pump the oil? Am I overthinking this? I have alot of pictures I'll post some as soon as I get a chance.
  9. ChapmanF
    18,961
    That's more or less what the car normally does, anyway. The battery and MG1 are powerful enough to crank the engine right up to normal idle speed and oil pressure before commencing any fuel injection or spark. (You normally don't notice when the engine actually "starts" as opposed to just being spun, unless you're listening very carefully.)
    -Chap
    m.wynn and acp380 like this.
  10. acp380
    acp380 Member
    71
    61
    US
    Thanks chap. That's good to know. Helps make me a little less nervous for when I hit that button. I made sure my battery was fully charged before I started this project. It' been 6 months. Hopefully it still has enough charge.
  11. acp380
    acp380 Member
    71
    61
    US
    That's what the engine looked like inside when I opened the valve cover. Had a lot of moisture where moisture shouldn't be. Also check out how scarred the camshaft is.
    Aaron Vitolins likes this.
  12. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Wow that can shaft looks rather rough doesn't it! Was this engine ever ran low on oil?
  13. acp380
    acp380 Member
    71
    61
    US
    Aaron it was regularly run low on oil. The first time i seen the orange triangle of death was when I realized I had an oil consumption problem. The car is driven 100 miles a day and it didn't take long to get low again and sometimes we would forget about it and not realize until the triangle would start flashing in a turn. Hopefully we take better care of this brand new second hand engine.
    m.wynn, Raytheeagle and Mendel Leisk like this.
  14. acp380
    acp380 Member
    71
    61
    US
    Got the crack welded up. Hopefully I can install it today and see if she fires up.
    Mendel Leisk and Raytheeagle like this.
  15. acp380
    acp380 Member
    71
    61
    US
    Forgot to upload pic
    CR94 likes this.
  16. acp380
    acp380 Member
    71
    61
    US
    She's alive!
  17. acp380
    acp380 Member
    71
    61
    US
    Well she's running good. However I put new struts and its still making the same clunking noises as before.
  18. acp380
    acp380 Member
    71
    61
    US
    I knew it was too good to be true. Now im getting a p0a80 code. The car runs awesome. Getting 47mpg(was getting 38-42 before engine swap),battery seems to be charging like it always has. The code has come up twice already. Once right when I got the car off the ramps and then on my 2nd trip in it. The first trip was about 50 miles. When the code occurred while going down the road I felt an instant power loss. Im guessing the computer does this? So I pulled over and cleared the code with my phone and it was back to normal. I drove home with no problems. My guess is the battery fizzled out while sitting for 6 months? I did read something about a bulletin saying something about the battery cooling fan getting dirty and restricting airflow causing the code. I think its a long shot. It wouldn't surprise me though. I live down a dirt road and with 4 kids the car is constantly dirty.
    Montgomery and Raytheeagle like this.
  19. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Worth checking the fan, but sitting for 6 months did the battery no favors:(.
    Keep us posted (y).
    acp380 likes this.
  20. acp380
    acp380 Member
    71
    61
    US
    Going to do that tomorrow. And replace the rear shocks while I'm at it. I bought them with the struts.
