2012 Prius fan runs automatically when engine is off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Brandi Bobrowski, Aug 26, 2017.
Tags:
  1. Brandi Bobrowski
    Brandi Bobrowski New Member
    Grover Beach, CA
    A fan begins running about 5 minutes after the car is turned off, happens only in the daytime and doesn't seem to matter the temperature or cloud cover. I've brought it to two dealerships to have it diagnosed, but they can't recreate the issue as they do diagnosis under a cover and the car only seems to do it if daylight is involved (meaning it's running for 8+ hours while I'm at work). Someone says the car does it to keep itself cool, but it started after an oil change and I don't see anywhere that says this is a normal feature. It shuts off for under a minute and starts again. Any ideas?
    52,883
    i think it's some kind of pollution control check, they all do it, no worries. (unfortunately, dealers are the least likely to understand hybrids) if they can't plug their scanner in and get a code, they're pretty much at a loss.
  3. Mendel Leisk
    42,368
    Would it be the solar roof??
    Maarten28 likes this.
    52,883
    you don't get one with the 'N/A' package.:cool:
  5. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Sure sounds like the interiour fan with the solar roof. When it runs, go inside the car and check if there is air coming out of the vents.
    But more importantly: where does the sound come from? Does it come from the engine bay? From the exhaust? From the tyres (yes I'm being pedantic but at this point it's anyone's guess).
  6. b100
    b100 Member
    145
    75
    Netherlands
    I think he has a solar roof and don't know it...
