2012 Prius Four Wiper Blades video
Discussion in 'Gen 3 Prius Main Forum' started by winner_downtheline, Sep 27, 2016.
  1. winner_downtheline
    winner_downtheline Junior Member
    Tampa Bay, FL
    Hello!
    Purchased a 2012 Prius Four from CarMax and noticed this noise (embedded video below) and want to see what others think. I am assuming it is some cheap wiper blades and if so please recommend some good ones as it does rain a lot in tampa bay. Thanks!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Definitely sounds like wiper blades. Are the original blades on it? If so, why not get the rubber inserts at the dealer and replace to original? If not and something else is on there, I replaced the drivers side with a Michelin blade.
    Works well for the short period of time it is required in Cali:).
  3. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I agree sticking with OEM blades. I have them and they work very well and quite a long time. From what I see in the video, you have aftermarket blades. If you don't mind dropping some dough on OEMs initially and replace with refills, you'll save a lot of money over time.
  4. winner_downtheline
    Tampa Bay, FL
    #4 winner_downtheline, Sep 28, 2016
  5. withmenilu
    withmenilu Junior Member
    Sri Lanka
    I had the same problem..
    Changed the wiper blades (didnt work)
    Cleaned the windshield with vinegar and newspaper (worked for a while but the haze came back)
    Then a friend recommended a windshield polish to remove the miro scratches off the windshield. The tech used SRP polishing compound with water and used a buffing machine with a felt pad.
    Did it and changed the blades again. The haze is gone and I can see clearly again.. Hope this helps
  6. Mendel Leisk
    42,299
    I've been using this:
    Go over the windshield first, then wipe along the wiper blades with a cloth wetted with it.
    Still on the original blades, they work just like new. The car is low mileage, almost always garage stored, could well be a factor.
    winner_downtheline likes this.
  7. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Depends if you still have the OEM Holders.
    Below are the complete assembly.
    FRONT BLADE for 2012 Toyota Prius|85222-75011
    FRONT BLADE for 2012 Toyota Prius|85212-47040
    Below is the refill only provided you still have the OEM Holders.
    WIPER BLADE REFILL, LEFT for 2012 Toyota Prius|85214-68020
    WIPER BLADE REFILL, RIGHT for 2012 Toyota Prius|85214-30390
    Try cleaning the glass and the existing blades first. If they still bounce, then go ahead and replace/rework them. Best of luck to you.
    FWIW, I also recommend the OEM blades. YMMV.
  8. winner_downtheline
    Tampa Bay, FL
    Thank you! The car has the wiper blade OEM arm and so I only need to buy the OEM blades. Will this be the same price at the dealership? Thanks.
  9. dorunron
    3,318
    1,105
    Houston, TX
    Prices online vs your dealer might be different. Maybe get the parts dept. to price match? Also, if you haven't done the refills before on the Prius, get the parts guy to show you how to do it. Metal blades in the arm have to be reused and only go in one way, plus rubber refill has a notch that goes one way. Once you have done it, the rest is history.
    Best of luck to you!
