2012 Prius Hatch "Bounching" Over Road Bumps
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by simonman, Oct 27, 2015.
  1. simonman
    simonman Junior Member
    Grand Rapids, Michigan
    Hello,
    I bought a 2012 prius 4 with 42k miles recently. The car is just too loud. I've determined the "noise" to be the rear hatch bouncing when I drive over small bumps in the road. The bounce creates an air pressure change that is just too unacceptable. I've milled the hatch lock mechanism's holes into slots to I can close the hatch tighter. This made a little improvement. My next step will be to add some gasket material on the hatch itself so it closes tighter. My slots allow the hatch to bottom out so I had to back off the adjustment a bit.
    Has anyone come up with a fix for this?
    Thank you,
    Dan
  2. bhyde
    bhyde Junior Member
    Arlington, MA
    52,862
    it's not adjustable? never heard of it before.(n)
  4. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    I'm betting it's the hatch floor storage bin and cover. Set the latches and make sure you don't have loose items just sitting on the plastic tray under the hatch floor. I use the rubberized mesh you can get for tool chests and kitchen shelving to absorb rattles and keep things from sliding around.
  5. simonman
    Nope, I have added Boommat XL and under carpet lite to the entire car including all the spare tire area. It is most definitely the hatch bouncing too much. I have another test I will try at noon today....
  6. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    On my 2010 there is a pair of black stops designed to engage each other at each side of the hatch, one on the hatch and one on the frame. The ones on the hatch are secured with one bolt and the matching ones on the frame are secured by 2 bolts with washers. Loosening the bolts on the frame (10mm wrench) permits you to slide the stop and adjust how tightly the door fits when closed.
    Adjusting these on my car made the car a lot quieter. It also seemed to be a bit more rigid.
    I assume that the 2012 is the same.
    Mendel Leisk and Eclipse1701d like this.
