2012 Prius: How to reset or get "check hybrid system" dash light to shut off?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dj7u, Jul 3, 2012.
  1. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    I was curious how you can get rid of an annoying "check hybrid system" dash warning?
    Let's just say I know for certain nothing is wrong. It's only cause I accidentally disconnected and reconnected a wire. Just need to reset is all.​
  2. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Remove battery negative lead from battery, let sit for a few minutes, reconnect. Reset the "auto down" windows and all your radio station presets.
  3. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    I've always been told to turn the car on and off 3 or so times. If the error doesn't clear, something may indeed be wrong.
  4. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    Where under the hood is the negative battery cable located? Is there easy access?
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oh boy...
    SB6 and guicide like this.
  6. LulzChicken
    791
    135
    Alabama
    If you believe the negative battery cable, or the 12v battery all together, is located under the hood then I question if you really did cause any serious harm to your car initially. The 12v battery is in the rear of the vehicle. If the error doesn't clear after several car restarts, take it to your dealer if it's under warranty.
    Refer to your manual if you'd like to take the issue into your own hands and wish to disconnect the (-) cable from the (-) battery terminal.
  7. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    You need high voltage gloves in order to safely disconnect it. :D
    All kidding aside, it is in the right rear corner of the trunk. The terminal is on the soft side so be careful.
    iPhone ?
  8. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    So, basically act like I'm trying to get to the spare tire and I should see it?
    It's on the passenger side in the rear?
    Earlier I said under the hood only cause most cars are.
  9. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Turn it off and on 3-4 times, it will go away.
  10. LulzChicken
    791
    135
    Alabama
    Look at your manual.
  11. Irish1
    Irish1 New Member
    If you have pulled the orange circuit breaker in the trunk and get a Hybrid system failure. Check to see if you failed to slide the orange handle to the lock position when you reinstalled it. Moves right. You may need to still reset the codes by disconnecting the 12 volt battery. Fire department says this is not necessary. This will reset the warning message.
    Excellent theft deterrent when parked in long term parking at the airport. Just slide it to the left.
    Junkyard likes this.
  12. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    Kind of crazy but I had this happen to me after I connected my Progressive get your discount thingie. I found that not only do you have to cycle the power switch but actually drive around the parking lot. It cleared for me after four resets with the motor cranking up.
  13. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    So, you just needed to restart about 4 different times and drove a couple minutes between each time?
  14. Southern Dad
    350
    212
    58
    Monroe, GA
    I have a circle driveway. I just drove around it. The fourth time that I powered up it cleared. I had tried it without moving and it just didn't do it.
    telmo744 likes this.
  15. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    Interesting, thanks for the tip.
  16. Patrick Perry
    Patrick Perry Junior Member
    Salt Lake City
    Better explanation:
    The Prius swerved unexpectedly and hit the median.
    Two tires blew and ruined two rims.
    The car was towed home.
    It was started several times and moved fine.
    The tires and rims were removed and replaced.
    Disconnected my hybrid battery lock many times and reconnected.
    disconnected the negative pole of the 12V battery and reconnected
    still get the message;
    Check Hybrid System.
    vehicle will not move or go into gear.
  17. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    yeah right.... /
    Grit likes this.
  18. Leadfoot J. McCoalroller
    7,847
    7,314
    Pennsylvania
    2018 Prius c
    Sounds like you still have undiagnosed damage from the offroad incident. Needs proper diagnostics to evaluate. Toyota Techstream software would be best, but even retrieving an error code with a simple 'dumb' code scanner would be a good start.
    Just hazarding a guess, there's either physical damage or water intrusion to the high voltage wires under the car relating to going off the road. A real diagnosis will be needed.
  19. ChapmanF
    17,275
    Presented with a code reader, the car will give trouble codes explaining why it thinks it is showing that message. That's where the diagnosis starts.
  20. Grit
    Grit Senior Member
    6,444
    4,185
    Wilkes Land
    Last year a car hit the local highway guard rail, driver said a wind gust caused the car to swerve. Last heard the wind's insurance premium went up.
  21. Grit
    Grit Senior Member
    6,444
    4,185
    Wilkes Land
