2012 Prius Instrument Cluster Display goes out
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by JJCreech, Nov 3, 2015.
  1. JJCreech
    JJCreech New Member
    Shreveport, LA
    The instrument panel on my Prius (speedometer, fuel gauge, etc. on the dash) keeps going out intermittently. Took it to the Toyota place and of course the lights were back on. Has anyone else had this problem and how was it solved? Thanks!
  2. mrbigh
    3,686
    699
    Long Island, NY
    have you check the console dimmer, to the left of the steering column ?
    Raytheeagle and GuitarGuy4Him like this.
  3. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    This happened to me this morning...as mrbigh said my 2 year old had turned the dimmer knob all the way down. As soon as the headlights came on the dash would go out except for the gear display. I have a 2012 also. I was glad that's all it was!
    Andyprius1 likes this.
  4. Zesha
    Zesha Junior Member
    Valley Center CA
    Make sure that a piece of paper or business card isn't Covering UP the prism reflection system of the Dash display
    All Indication viewed comes from the bottom of the dash and the actual indications reflects on to a horizontal screen which is viewed by the driver
  5. Zoran Petkovic
    Zoran Petkovic Junior Member
    Budva, Montenegro
    I have the same problem, fuel and milage gauge going off and ON from time to time. I remove instrument cluster and check all solder points - all was OK, on PCB where is fuel display one big transistor is going hot, transistor was checked OK, there is one small IC which generate square signal for two MOSFET-s - also OK, but big transistor haven't trigger signal and going HOT.
    any suggestion?
    small HUD display is OK and big right (center) display also working normal.
    Gen 3
  6. GuitarGuy4Him
    GuitarGuy4Him New Member
    Ga
    Mrbigh,
    Thank you for that conment!!
    I somehow had the lights on and the dimmer all of the way down. Occom's Razor at it's finest!
