2012 Prius low beam fuse
Discussion in 'Gen 3 Prius Technical Discussion' started by john reynolds, Jan 17, 2017.
  1. john reynolds
    john reynolds New Member
    new jersey
    Hi all, my GF has a 2012 prius hybrid, so I think I'm in the proper forum. Her low beam headlights stopped working so I popped the hood, knowing nothing about her car, and located the fuse box on top the driver side tire. According to the diagram, locations 20 and 29 hold the 15A fuses for the low beams, but they are missing! Perplexed , I wiggled the connector on the driver side light and it came on. I had to replace the other side's bulb with an H11, and now both lights work -- with the fuses missing! What am I missing here? Thanks John
  2. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    I don't think they changed the fuse layouts from 2010 to 2012, but I could be wrong. See attached.
  3. ChapmanF
    19,007
    Prii with different option levels and sold into different markets can have significant differences in the headlight wiring (and other wiring too). I don't know about 2012 specifically, but I know my 2010 headlight circuits would have been quite different in the Canadian flavor with DRL, for example. I generally find the legends printed on the fusebox covers to be about as useful as the scrawls on the door of the circuit breaker panel at your grandfather's house, because they cover several variations. A lot of the time, they give enough of a hint to find the right fuse. When I really want to know what's on what fuse, I do go to the wiring diagram, which shows all the variant possibilities and which versions of the car they are used in.
    Don't forget there's also a fuse panel under the instrument panel. (Is it the gen 4 that also has an additional 2-fuse holder tucked under the left kick panel ahead of the door trim? I forget....)
    -Chap
  4. john reynolds
    new jersey
  5. john reynolds
    new jersey
    Thanks for the info. I figured it out. There is a 40A fuse labeled P/I 2 that handles both low beams and other things in my box. The 2 unused low beam fuses threw me off. Toyota must have decided to combine the lo beams with P/I 2 after they made the fuse box.
  6. ChapmanF
    19,007
    There are probably other variants (different trim levels or in different markets) where those are used. :)
    -Chap
  7. mikejaz2
    mikejaz2 New Member
    oak park il
    Hi all, new memberl here...this is pretty distressing...the fuse diagram in my owner's manual is waaaaay different than the one RRxing linked to up above...thanks for that, and I think I've come to the same conclusion as John Reynolds.
    Now I gotta go wiggle the low beams and see if they work...for some reason, both of them stopped tonight!
