2012 Prius making humming noise when driving especially on highway
Discussion in 'Gen 3 Prius Technical Discussion' started by waznme, May 3, 2019.
  1. waznme
    waznme New Member
    New Hampshire
    I have a 2012 Prius... Started making a humming noise about a month ago... I thought it was my tires at first because I knew I needed new ones. Got 4 new tires and still hearing the hum. It seems louder the faster I am going. Also one time around that time, I had to accelerate to move over to exit the highway (close to 80) and all of the sudden my check engine light came on. After I exited the highway it went out and has not come on since. I think that was about the time I started noticing the hum.
    The noise is loud enough that people can hear it on my phone (i'm using my bluetooth).
  2. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Check your oil level.
  3. Mendel Leisk
    42,355
    How many miles on it?
  4. jadd806
    jadd806 Member
    45
    34
    MA
    Bad wheel bearing is another avenue to investigate.
    Does the sound change only with speed, or with engine demand? i.e. if you floor it, does that change the sound?
  5. waznme
    waznme New Member
    New Hampshire
    approximately 170k
  6. waznme
    waznme New Member
    New Hampshire
    No, it doesn't change... just a loud humming sound. I've heard some say maybe a fan? It's hard to tell, but I think it's coming from the back. It only gets less loud when i slow down and when i stop it's gone completely.
  7. bisco
    52,863
    so, it does change with speed
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Could be HV fan, fan rpm goes up w speed. Maybe there’s something lodged in the squirrel wheel case. Or fuel pump on its way out. I don’t have rear seats in mine so I hear the hv bat & fuel pump all the time as rpm goes up
  9. ThatDudeOrion
    ThatDudeOrion Member
    95
    87
    Central, NJ
    I thought the HV fan increases speed with traction batt temp? I never realized it goes up with rpm
  10. Mendel Leisk
    42,355
    just temp.
    ThatDudeOrion likes this.
  11. ChapmanF
    19,038
    That's generally a good sign. There's pretty much nothing back there to make a speed-dependent humming sound other than a wheel bearing.
    If you have some way to recognize the pitch of the sound at known speeds (a tuner, or perfect pitch if you have it) you can do some more checking to be sure it's not something else. Rear wheel bearing was exactly what it turned out to be for me that time.
    That thread ends with a link to a continuation where I had a front bearing go next. The pitch/speed relationship is different.
    A ChassisEar turns out to be really useful in pinning down the culprit bearing.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    My mistake, Mendel is right; fan speed correlates to bat temp. I was thinking of the PID torque app that you can customize voltage to go up as rpm goes up.
  13. Mendel Leisk
    42,355
    FWIW, I could never hear the hybrid battery fan, even when it was on speed 4 (as displayed on ScanGauge). I think there's speeds 5, and maybe 6?
  14. ThatDudeOrion
    95
    87
    Central, NJ
    I can hear mine sometimes on hot days when I'm stopped and the ICE is not running. But i can't say I've ever noticed it outside of that scenario.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I’ll say 6 according to hybrid assistant app, there’s speed 1 - 6 on it. It’s always set to 6 during summers in my car. Boy it sure is loud but my jams at vol 63 masks it.
    Raytheeagle, RMB and Mendel Leisk like this.
  16. Rockky
    Rockky Junior Member
    Chicago
    Was this ever resolved? My Prius 2012 is making a loud humming noise from the rear. The faster I go, the louder it sounds. Feels like there is a drag to the car,and if I let go of the gas a high speeds the car continues to hum just as loud. Almost feels like I’m in a semi.
  17. bisco
    52,863
    wheel bearing?
  18. ChapmanF
    19,038
    The great thing about humming noises from the rear is there really ain't much stuff back there to make humming noises besides wheel bearings.
    Can you tell if, not just the loudness of the hum, but the pitch of the hum changes with the road speed?
    Some very musical people might be able to hear the pitch and name what pitch it is. Some very nonmusical people might be thinking "pitch? what?". A lot of the great middle of people might not be able to name the exact pitch but could definitely say whether it goes higher with road speed or not.
