2012 Prius model IV vs. V - mods
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Big Steve, Apr 6, 2012.
  1. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Ignoring option packages the differences between the IV & V seem to only be three things:
    1. Headlights (halogen vs. LED)
    2. Fog lamps
    3. 17" wheel size.
    Am I wrong or can't all these be accomplished on a IV with stock Toyota parts. For the first two, I would be surprised if Toyota had a different wiring harness. Can I but the appropiate parts from the service desk to make the mods?
    For the wheels the fix seems to b an obvious change, no? If so, why would I want the larger wheels?
    Sorry if these are naive questions from a newbie. I have seen many pots about mods, but I don't think any cover this/these question.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Wouldn't the MSRP difference between the model Five and Four ($30.6K vs. $29K, or $1.6K) be less than the cost to do the 3 things you listed? My guess is that just the LED headlights alone would be more than that. Why go through the cost and hassle? Plus, unless things have changed for '12, the Five has more responsive steering.
  3. yeldogt
    yeldogt Active Member
    810
    313
    NE
    On my 11 the wheels and tires would cost you more than the final price I paid for the five upgrade. The LED''s .... once adjusted .. are worth the price of the upgrade. The FL are worthless IMO. You could only get the AT package on the five. No sunroof.
    Also the LED headlights require the headlight washers -- so the bumper is different plus those components and the switch/relays in the cabin to make them work. You must have the washers w LED's -- Just like HID's the lights do not get hot enough to melt and snow and ice -- you need the washer fluid with a foaming agent and deicing solution.
  4. Big Steve
    402
    39
    Richmond VA
    1. As stated, with the V I could not get the sun/solar roof.
    2. Fog lights not worth it? I love them on my Outback, especially on back roads.
    3. I see the problems you mention w/ LEDs. How do people solve that with the LED mods I see on here?
  5. stream
    2,977
    452
    Long Island, NY
    I must have missed that in your original post. :confused: ;)
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Sure, but the LED headlight is $800 a pop so they'll run you $1600 to retrofit. Might as well get the Five.
    Also, the Five has headlight washers, although quite useless depending on where you live. You don't actually need them.
  7. Big Steve
    402
    39
    Richmond VA
    Sorry Stream, I meant as Yelgogt stated... I would not be able to get sunroof. I now have IV w/solar coming. Already thinking about mods.
  8. stream
    2,977
    452
    Long Island, NY
    Got it.
    Enjoy the new car, and let the modding begin!
    There are lots of online parts sources that are typically significantly cheaper than the dealers, so I'd suggest searching online and then see if your local dealers will price match--some will--if not, buy online.
  9. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Just stick HIDs in the Four headlights. Much cheaper and they do quite well in the projector headlights.
  10. Tideland Prius
    16,681
    Yup, the LED headlight retrofit will cost you at least, if not more, than the asking price between the IV and the V (or Four and Five).
  11. Big Steve
    402
    39
    Richmond VA
    What is the proper "grammar" here?
  12. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    You forgot the head light washer
  13. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Both are pronounced "four" and "five," as IV and V are Roman numerals. It's just that Toyota used to label these trims IV and V in 2010 and have since switched to Four and Five since 2011 to avoid confusion with v (pronounced "vee") for the wagon.
  14. danielizzle
    danielizzle Eco Swag
    153
    Anaheim California
    I've always wanted to see a comparison shot betweed LED and HID see whats the big difference. The HID seems the most reasonable considering its only a buck fifty.
  15. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
