2012 Prius No Power until dome light is turned on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by K Dog, Aug 2, 2014.
  1. K Dog
    K Dog New Member
    Fixed my gremlin with mysterious lost power. Looseven ground battery terminal on 12th battery. No idea why dome light brought it back to life, but a week after tightening, no more issues.
    ftl likes this.
  2. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Here are some voltage readings from my >2 year old Toyota True Start, 84 month warranty, p/n: 00544-21171-325 battery.
    The battery had been replaced before I purchased the vehicle.
    Voltage readings were taken with a Fluke 87III & verified with a Fluke 73III.
    This afternoon I had been driving the Prius & got home ~6:30pm & locked the car.
    About 8pm I unlocked the car, popped the hood & took some measurements.
    12.96 12.97 12.98... after 5 minutes it was up to 13.11V
    The above document from Toyota says "turn on the headlights for 20 to 30 seconds. This will remove the surface charge from the battery".
    I turned the headlights on for 30 seconds then turned them off.
    12.96 after the headlights were off for 1 minute.
    13.00 after the headlights were off for 2 minutes.
    That was the end of the test.
    Recently I had the inverter replaced & in that thread
    2010 Prius died - P0A94 - Inverter Failure - Replaced | PriusChat
    on June 28, 2014 I wrote the following:
    "I just checked the 12V battery after the vehicle has been sitting all night...
    12.93V at the fuseblock terminal - measured with Fluke 87 III"
    This reading was after the Prius had been unlocked in the AM & the door opened to pop the hood.
    This Toyota battery is a true AGM battery which will read slightly higher voltage than an older style flooded lead acid battery.
    All voltage readings were made from the fuseblock terminal to engine ground.
    #22 kc410, Aug 9, 2014
    52,899
    like brand new.;)
