2012 Prius oil change worry
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lipsoid, Nov 15, 2016.
  1. lipsoid
    lipsoid Junior Member
    ireland
    I have a 2012 Prius with 40000 miles. Yesterday I did my first oil change since buying the car in May 2016. I drove the car onto ramps, then proceeded to drain the oil (not the filter). As I lay under the car the engine started! In a panic I rushed to shut down the engine within 3-4 seconds from it starting. I had forgotten to press the Power button to fully switch off the car after I had driven onto the ramps.
    Now worried damage has been done??
    52,657
    welcome! i don't think you can cause any damage in a few seconds. the car starts millions of times over its life under the same conditions. it takes time to pump the oil up and through. no worries, just glad you weren't hurt.
    Rebound likes this.
  3. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    Yes you will fine.
    Rebound likes this.
  4. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    All good.
    Rebound likes this.
  5. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    4 seconds? Definitely no damage.
  6. Mendel Leisk
    42,132
    Just to fill in the picture: was the oil draining, completely drained?
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I did the same thing when I changed my oil. Actually, I broke the oil filter canister trying to unscrew it. I drove the car down in EV and parked it back into the garage. Then, I went to buy a new filter canister in another car. When I came back I drove the PiP back on the ramps but EV just didn't have enough power and I triggered the ICE for a few seconds.
    Oil splattered all over the ground. Quite a mess and I felt quite stupid. 35,000 miles later (currently at 115k), car does not appear worse for wear.
  8. Mendel Leisk
    42,132
    I quit using ramps about 30 years back, switched to floor jack and safety stands. Just too much excitement: running car up ramps, freaking out that they would kick out, or I wasn't going up straight, or would run past the wheel stop at the end.
    mmmodem and Raytheeagle like this.
  9. mmmodem
    2,732
    1,703
    Bay Area, CA
    I know, I hate the ramps. It's just that stupid flap covering the oil pan. I can't get the car high enough off the ground with a jack and stands without needing to severely bend it out of the way. I grab the mirror from our bedroom to see where I am with the tires on the ramp.
  10. Mendel Leisk
    42,132
    I take the whole panel off. A bit extreme maybe? Consider a 3 ton jack, for more lift.
    Raytheeagle likes this.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Relax you're fine. It takes a long time.
  12. Siward
    Siward Active Member
    314
    128
    Toronto
    I think you will be fine. Motor oil serves to lubricate and keep the engine from overheating. It can't overheat because you didn't keep your car on too long without oil. Lubrication shouldn't be an issue because even with a oil drain the parts should still be coated with some oil unless you keep the car on too long.
  13. lipsoid
    ireland
    Not completely drained but most was drained, was just a fine amount coming out.
  14. lipsoid
    ireland
    Thanks for the replies. They put me in at ease.
    Rebound likes this.
