2012 Prius: Phone, Bluetooth and Aux issues
Discussion in 'Gen 3 Prius Audio and Electronics' started by ESri, Mar 1, 2022.
  1. ESri
    ESri Junior Member
    Portland
    Hello, I started having issues connecting my phone to the Prius - both with Blutooth and Aux port. I am unable to use the Apps or Setup buttons. Appreciate any suggestions on what would be recommended next steps.
    Thanks
    Easwar
    52,822
    do you have anything connected to the obd port?
  3. ESri
    ESri Junior Member
    Portland
    52,822
    could be going south then. try pulling the fuse to reset it
  5. uskallen
    uskallen Junior Member
    Houston
    Did you find a solution to this? I think I'm having the same issue. When I press the Apps, Setup and Phone buttons to the right of the screen, nothing happens. It's like it's not equipped with these features but I'm pretty sure it has navigation and bluetooth. Backup camera works though. The cigarette lighter port works, but the USB port doesn't.
