2012 Prius plug blown head gasket?
Discussion in 'Gen 3 Prius Technical Discussion' started by Frank A. Estrada, Mar 9, 2020.
  1. Frank A. Estrada
    Frank A. Estrada Junior Member
    Walnut ca
    Original owner. 280k miles. On cold starts plus low rpm acceleration the engine knocks as if in 3 cylinders. I removed the 0ring on the radiator cap and problem goes away. I’m assuming engine pressure buildup is the culprit. Could it be Intake manifold or other areas besides head gasket? Thanks for any
    Help.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat(y).
    Some questions:
    • Any dash lights?
    • What are you using to read the codes?
    • Could it be the water pump?
    • Cleaned the egr circuit stem to stern?
    Good luck and keep us posted(y).
  3. Mendel Leisk
    42,322
    That's interesting. And sounds vaguely familiar, someone else found the same thing??
    A PIP with 280K miles, likely at least half utilizing the engine, Hybrid Vehicle mode? 140K miles is about the time regular Prius start having head gasket failure.
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Im surprised it made it to 280k! When my sisters 2010 head gasket blew we replaced it with a 2013 Prius plug-in engine with only 45k. (I saw the car it came out of) after putting about 35k on the “new” engine, it’s head gasket blew. I was and still am a little shocked and disappointed. But it still runs, been running that awful stop leak for over a year. It’s not worth replacing an engine a second time.
  5. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    Here is a reply to a similar problem reported here some time ago. " Removing the radiator cap o-ring unseals the system, placing less hydraulic pressure on any head gasket leak -- including after shutdown, during the cool down cycle. Not a fix, a palliative."
    "A possible middle ground is a different cap that seals the system at a lower PSI relief pressure. (I do not know what PSI the OEM cap is rated.) That said, you will still lose some coolant, maybe a lot, depending on ambient temperature and ICE duty cycle."
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The OE cap is 19psi. When cars had a conventional metal cap, the final two digits of the part number indicated the PSI. Then Toyota and other automakers used a smaller cap, then came plastic caps and the like. I seriously doubt that you will find a lower PSI cap. Removing the o ring compromises the system integrity as bad as the blown gasket. It needs a mechanic, or some “mechanic in a bottle”.
  7. Frank A. Estrada
    Walnut ca
    I checked the under the engine and looked at the head gasket exhaust side. Sure enough the gasket is wet around the edges. Time to R&r the head. 280k miles not bad for a head gasket to live that long.
  8. bisco
    52,819
    actually, much better than most gen 3's. how many ev miles do you get now?
  9. Frank A. Estrada
    Walnut ca
