2012 Prius Plug in 100 K maintenence
Discussion in 'Newbie Forum' started by Tina Pariani, Jan 19, 2021.
  1. Tina Pariani
    Tina Pariani New Member
    texas
    Hi guys,
    I have a 2012 Prius Plug in that's coming up on a 100 K miles. All I have been really doing is changing the oil. Is there anything else that I need to do? I'm afraid to take it to the dealership to ask the same questions as am afraid to be stuck with a big bill for fluff so thought to ask you guys & hopefully take it to my local mechanic to have those items taken care of.
    TIA!
    Tina
    mikey_t and bisco like this.
  2. Solar Blue
    Solar Blue Member
    58
    28
    Columbia River Gorge
    52,695
    clean the hybrid cooling fans and intake grilles
    brake caliper slide oins should be lubed
    probably want an a/c check in texas
    is the 12v original?
    have you never changed the cabin and engine air filters?
    if you don't have a maintenance schedule, you can get one at toyota.com/owners
    mikey_t likes this.
  4. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    The cabin and air filters are really easy to change by yourself and will save you around $60 at the dealership. Aside from what's mentioned above, I'd probably change the transmission fluid.
    How much longer do you want to keep your car?
  5. Mendel Leisk
    42,194
    Toyota US specs engine coolant change at 100k or 10 years (inverter coolant delayed till 150k etc).
    I’d also clean Exhaust Gas Recirculation and Intake Manifold.
