2012 Prius Plug-In: Dead as a Doornail
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by old5ten, Oct 18, 2017.
  1. old5ten
    old5ten New Member
    Bay Area, CA
    hi all-
    i'm the new owner of a 2012 prius plug in. drove the car successfully for a couple of days, no problems. last sunday i drove it, then parked it in the driveway and everything went dead. no power button, no door looks, nothing. it seemed like an automatic full shut down of everything. any ideas what the source of this could be? the car ran fine up until that point.
    thanks,
    elmar
  2. Mendel Leisk
    42,361
    Check the 12 volt battery for starters.
    (Think I beat @bisco, lol)
    m.wynn, Montgomery, bisco and 5 others like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Yup! A dead 12V is the most likely cause I can think of. Same as with a regular car.
    I think I beat him too, @Mendel Leisk. What a coup!! :LOL:
    m.wynn, bisco, Raytheeagle and 3 others like this.
  4. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    And once you jump-start it, look to see if you left a courtesy light on, or a door ajar, or if a door or hatch switch might be mis-adjusted and not shutting off the courtesy light. Those will drain the battery.
    jerrymildred and Mendel Leisk like this.
  5. old5ten
    old5ten New Member
    Bay Area, CA
    ok, thanks. i'll try jumping it. i'm just confused by the fact that it started fine, then ran fine, then died when i turned it off. seems like if it was a dead battery it wouldn't have started fine initially and the 12v battery shouldn't be fully discharging while i'm driving?!
  6. Mendel Leisk
    42,361
    Check the voltage with a digital multimeter first, see where you stand.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    EVERYTHING usually works right up to the instant that it fails. Think a blown light bulb.
    And......the charging system can often keep the car running even with no battery, until you turn it OFF of course.
    It is a bit unusual for it to go completely and totally dead though. Might just be a loose cable.
    N.J.PRIUS likes this.
  8. KCobby
    KCobby Member
    229
    74
    NYC area
    If it's an original 12v battery, it's due. And the 12v is only used to start up. Won't affect the running. Good luck!
  9. Sam Spade
    2,036
    1,024
    2017 Prius c
    Actually it can and often does.
    Because the charging system doesn't operate exactly right with no battery present.
  10. mrbigh
    3,686
    699
    Long Island, NY
    OMG...:barefoot: BISCO didn't post anything yet?
    as evrybody said, after jump starting the vehicle, check for doors ajar or the rear hach door
  11. Prodigyplace
    12,718
    11,850
    Central Virginia
    The 12v battery is only used to boot up the computers and close the high voltage relay.
    The high voltage traction battery starts the engine, if needed.
  12. bisco
    52,876
    grandchild, dentist and recycling day, who's got time for priuschat?
    thanks for filling in fella's!(y)
  13. old5ten
    old5ten New Member
    Bay Area, CA
    thanks for the suggestions. checking the voltage seems like a good first step. i'll have access to the car on friday, so we'll see what happens then.
  14. bisco
    52,876
    be careful if you jump start. cross polarizing can cause thousands of dollars in damage. pip charges the 12v while charging the hybrid battery, have you been plugging in?
    N.J.PRIUS and jerrymildred like this.
  15. Rav
    Rav Member
    92
    52
    San Jose, CA
    Similar thing happened to me, I also have a 2012 but I was driving and mine completely shut down. Yes, while driving. In the end, Toyota determined my hybrid battery was the culprit and they replaced it (free of charge).
    Data Daedalus likes this.
  16. Mendel Leisk
    42,361
    Geesh, how many miles?
    This might be the first PIP battery failure? (n)
    Data Daedalus, bisco and jerrymildred like this.
  17. jerrymildred
    11,517
    14,171
    Tampa, FL
    WOW!!! Glad it was a total fail, though, and you got a new battery with no arguments.
    I wonder what's happening with @old5ten.
    Rav and bisco like this.
  18. bisco
    52,876
    i'll be curious to know how many miles as well. i can't recall anyone else replacing a battery.
    jerrymildred likes this.
  19. jerrymildred
    11,517
    14,171
    Tampa, FL
    That the first I've heard of for sure, but I think I remember once reading that someone said they thought they'd heard of one. Which is about as nebulous as you can get.
    Data Daedalus and bisco like this.
  20. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    check the 12 vo............................. oh never mind....
    im going to suggest the blinker fluid from now on..
