2012 Prius Plug-in headlight
Discussion in 'Gen 3 Prius Main Forum' started by Arbin Kumar, Apr 26, 2023.
  1. Arbin Kumar
    Arbin Kumar New Member
    7593 Sangiovese Dr
    Need some help on a 2012 Prius Plug-in, left front headlights does not work and nor does the DRL (LED) on the bottom. Thought it was the intergrated relay, replace it but still does not work, blow the fuse on top of the relay. Any ideas, or a detailed wiring diagram so I can trace the wires back to see if what is shorted.
    Thanks for the help.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    the problem is, our headlight, the bulb cannot be replaced. you have to replace the entire headlight housing.
    I ended up purchasing these and working on obtaining a bulk supply at this time. I can't believe the price of one headlight housing from the dealer... bonkers!
    52,849
    are you sure it's a base? mine took a regular bulb, and there's no drl's.
  4. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    that and DRL at the bottom had me confused...
