2012 Prius refused to Start. Error Code P0335 – Crankshaft Position Sensor A Circuit Malfunction
Discussion in 'Gen 3 Prius Technical Discussion' started by Chuba, Sep 15, 2021.
  1. Chuba
    Chuba Junior Member
    45
    Nigeria
    Good day every one.
    My 2012 prius stopped me on the road. It's having 140,000 miles on it. I scanned it and I'm getting P0335 crankshaft position sensor A circuit and P0A0F.
    I have changed the crankshaft sensor still the engine refused to start. The wiring harness has been traced to the brain box and it shows there is no damage to the wiring harness. We opened the engine and checked the crankshaft reluctor wheel and it's in good condition. The timing is also good.
    Still the car refused to start.
    The car only drive on HV battery but the engine will not start.
    Before now I was having rattling and knocking noise. When ever it's idea or moving at low speed with the HV battery being charged. If I speed the rattling noise stops. I do not lose power. Which I was yet to find out the issue.
    Please what else can I check to resolve this P0335?
    Is Changing the engine and transaxle solve this issue or could it be bad brain box?
    Please solution needed.
    Thank you.
  2. ChapmanF
    19,055
    The players in that game are the crankshaft position sensor, the wiring and connections from there to the ECM, and the ECM itself.
    If you're sure the sensor and the wiring and connections have no problems, the ECM is what's left.
    However ... it is not at all common for ECUs to fail. That could be a reason to review carefully what steps you used to become convinced the wiring and connections and the replaced sensor are definitely good, before condemning the ECM.
    Are you able to crank the engine over by using a power tool on the crank bolt, for example? If you attach a scope at the sensor wires where they meet the ECM, do you see the expected waveform?
  3. Chuba
    Chuba Junior Member
    45
    Nigeria
    Yes Sir, I'm able to turn the engine but we didn't read any thing while turning it. We only turned it to check if the engine is knocked.
    We also changed the gasket because of the knocking and rattling noise I was hearing before.
    Note
    If I clear the error code and push the start button. The ready light comes on and I will hear some sound inside the transaxle may be trying to start the engine. After like continues 5 seconds of the engine not starting the check hybrid and check engine light comes back on the dash and the transaxle noise stops. The ready light stays on and the car will only drive on electric.
  4. ChapmanF
    19,055
    You reported a P0335 code, which is a certain indication that either (1) the crankshaft sensor signal isn't properly reaching the ECM, or (2) a proper signal is reaching the ECM but the ECM thinks it is not proper (which would make the ECM at fault).
    An oscilloscope at the ECM connector where the crankshaft sensor wires arrive would be about the most definitive way to distinguish (1) from (2). If the signal is poor, you can concentrate on what is wrong with the sensor or wiring to make it poor, or if the signal is good, you can conclude the ECM is at fault.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    I would suggest unplugging the ECM connector that has the wires for the cam and crank sensors. Then carefully back probe each circuit (from the wire side, not the terminal side that goes towards the ECM) and test resistance for both sensors (see the service manual for specs)- and check for any resistance to ground (should be infinite resistance).
    If that checks out ok then you may need to have someone with a 2 channel scope test both sensors to see if they can put out correct signals and that the signals are in the proper relation to each other (aka- correct cam timing or "sync").
    Sometimes a bad sensor can fool the ECM into coding the "good" sensor- as can a cam that's out of time. IF you can verify that both signals are correct and sync is correct THEN I might consider the possibilty of a bad ECM (after load testing all ECM power and ground circuits).
  6. JamiFids
    JamiFids New Member
    Four Touring
    I recommend that you contact an electrician. You may have a malfunctioning sensor.
  7. Chuba
    Chuba Junior Member
    45
    Nigeria
    Things done so far.
    I have
    1. Tested the crankshaft position sensor and its within Toyota specified range. Which means sensor is OK.
    2. I have changed the Crankshaft Position Sensor,
    3. I changed top gasket
    4. I inspected the crankshaft reluctor wheel and it's OK and well seated in its position.
    5. Timing chain inspected and it OK.
    6. Finally I have changed the ECU or brainbox
    So after changing the ECU or brainbox the car did not still start. If I start it, ready mode comes on and I will hear sound that sound like the brake pumps pumping from the engine side then the check hybrid system light and check engine light comes on and then the sound stops.
    The car can drive on EV mode only. The engine does not start.
    Pls note: this car was having knocking and rattling noise before this whole thing happened.
    I will like to know what kicks the engine. I kind of think that will be my problem.
    If I can change that which kicks or starts the engine I kind of feel the car will start.
  8. ChapmanF
    19,055
    What are the trouble codes that now appear, after your most recent changes? That's the first important information to get.
    What starts the engine is the motor-generator MG1, located inside the transmission. It is difficult to access. More to the point, there might not be much reason to suspect it, at least not before knowing the most current trouble codes.
  9. Chuba
    Chuba Junior Member
    45
    Nigeria
    The old codes are what I still have.
    Which are P0335 crankshaft position sensor and P0A0F.
    There were no codes when the engine was rattling and knocking.
    I'm now considering changing both the engine and transaxle
  10. ChapmanF
    19,055
    Have you made any effort to rotate the crankshaft (by hand, with an assistant, or with a power tool) while observing the crankshaft sensor signal at the ECM connector with an oscilloscope?
    I see that you have posted this:
    ... by which I suppose you mean that you tested the sensor with an ohmmeter. So it was in the specified resistance range, which does make a sensor issue look less probable.
    On the other hand, you now have two different ECMs agreeing that there is an issue with the sensor signal.
    That could be a good reason to go further and view the sensor signal on a scope while the crank turns, as mr_guy_mann suggested in #5.
    "whatever remains, however improbable, must be the truth."
  11. Avantis
    Avantis New Member
    West midlands
    Hi I have this same problem let us know if u solve it
  12. Avantis
    Avantis New Member
    West midlands
    Have done zero point calibration.?
  13. ChapmanF
    19,055
    Hi have you gone through the troubleshooting steps for your code in the repair manual (more info) yet?
    A lot of the time that will get you directly to the solution. If there's something about the issue that still stumps you even after that, the brain trust here can bat it around some.
  14. Avantis
    Avantis New Member
    West midlands
    Hi thanks for replying
    Basically car has p0335 code and won't start. Tried new crank sensor checked wiring changed invertor. Checked hv battery it has 215v dc.
    Now stripped out timming chain and reluctor ring has slight play when rotated on crank shaft.
    Think I will replace new reluctor ring and if still won't start then change transmission any input guys.
  15. Avantis
    Avantis New Member
    West midlands
    U had any further luck progress
    I have exact same problem.
  16. tony_2018
    tony_2018 Member
    227
    68
    so you reprogrammed your smartkeys too?
  17. ChapmanF
    19,055
    Hi I was wondering whether you were using the troubleshooting steps in the manual to kind of focus you on the things you can check that might lead most quickly to a solution.
    It sounds like you're trying a lot of things and will probably get it sorted that way eventually. I'm just not sure I would have the patience or money to attack it that way.
  18. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    just had one set that code, ended up being cam sensor Wth? Car just gets confused…
  19. Scott Stahl
    Scott Stahl New Member
    New york
    Ok I’ve just been thru this code with no start as well ….. have you verified if the engine is turning over at all when starting is initialized.
    Because if you look in and see that that crankshaft is not turning at all …and have a po335 code which makes sense since the sensor isn’t providing any data….you have likely have a busted output shaft on the transmission. That’s what mine was POW
    Snapped right off .
    Avantis likes this.
  20. Avantis
    Avantis New Member
    West midlands
    Thanks for ur inputs, I still have to remove engine to see what's happing with cvt shaft flywheel etc. Will keep u updated, worse case is a engine and transmission replacement.
