2012 Prius Replacing driver side fender
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sync801, Jan 29, 2017.
  1. Sync801
    Sync801 New Member
    16
    SLC UTAH
    Does anyone on here know to replace the driver side fender on a 2012 Prius?
    My headlight had gotten smashed and so I ordered the parts to fix it and got a few tools. I seen a video on how to replace the headlight and front bumper but since my side fender is damaged I'm tryna replace it now but can't find anything online. Any advice?
  2. Sync801
    Sync801 New Member
    16
    SLC UTAH
  3. Newsie11
    Newsie11 Junior Member
    CNY
    2014 Prius v wagon
    Slides on from the front. Toughest part is getting the little c clips to catch the studs that are near the small triangle glass. You will need some sealant for the weather stripping near the cowl. Next bolt it in, then attach inner fender.
  4. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    The OP's car might've sustained some damage to the mounting areas in the front, or they might be out of alignment.
  5. Sync801
    Sync801 New Member
    16
    SLC UTAH
    update: Thats what happened. We managed to get the new fender on and it looked okay for awhile, though it wasnt lined up perfectly and then a few days later the door started denting the fender in
