2012 Prius Spark Plugs Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HaiImBrian, Feb 14, 2017.
  1. HaiImBrian
    HaiImBrian Junior Member
    45
    Los Angeles
    Hello all! Been lurking for sometime now while I've been searching for my prius. Now I can proudly say I am a new owner of a used 2012 Prius III. Thank you to the community for all the help and information!! Drove it home last night and I am in love.
    With that being said, I want to do a complete maintenance overhaul on the car.
    I can't find anywhere what the official spark plugs are for the car. I don't trust autoshop websites as their data base maybe outdated.
    What plugs are you using in your gen 3 prius?!
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
  3. HaiImBrian
    45
    Los Angeles
    Thank you for your reponse!
    I did some more googling and found a toyota chart recommending Denso SC20HR11
    Whats the difference between this one vs the Denso (4711) IXEH20TT
  4. Mendel Leisk
    42,271
    This is from the Owner's Manual, page 566:
    If you don't have Owner's Manual, you can download pdf format from Toyota TechInfo. Just google that phrase, it'll one of the first few links. Pick the "manuals" tab, fill in your vehicle's details, and search.
    If you're using anti-seize (sparingly) on the threads, I would go with 13 foot/pounds torque. Dry threads: 15 ft/lb.
    There's a singnificant amount of disassembly needed to get to the plugs. Have a look at @NutzAboutBolts video on spark plug changing, here (pinned at top of 3rd gen maintenance sub-forum):
    DIY Auto Projects (formerly Nutz About Bolts) Prius Maintenance Videos | PriusChat
    (note, he says 20 ft/lb, I think that's too much, especially with anti-seize applied)
    You'll need a 9/16" spark plug socket, btw.
    I'll attach some info from the Repair Manual. There's another bit, outlining basically the parts removal in the above linked video, but I haven't separated it out yet, and the video is clearer anyway.
  5. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Denso TT is a new and improved version of the original plug design.
    DENSO IRIDIUM TT
    Here's the Toyota Spark Plug application chart:
    http://www.toyota.com/toyota-owners-theme/pdf/09_SparkPlugs2015_final[1].pdf
    I replaced the original plugs in my 2011 Prius with NGK laser iridiums and have no problems with them. I noticed no difference at all, yet, between the NGKs and original Denso. Therefore, I cannot say how much or if the new TT design from Denso improves performance. If others say they are good, and you are going to stick with Denso, I would go with the TTs.
  6. Mendel Leisk
    42,271
    NGK and Denso often have near-identical offerings. Our Civic Hybrid had 2 plugs per cylinder, and (maybe just for equal billing) used one of each.
  7. HaiImBrian
    45
    Los Angeles
    Wow this is great information!!! I am definately a DIY kinda person and will use these steps.
    I've always been iffy with NGK just because I try to stick with the Denso that Toyota offers. I'll definately be going with the TT's as I'm glad there is a new spark plug version out.
    NGK and Denso are the go to brands! Seriously people! Why even bother going with alternatives as it is only a few bucks more.
  8. bisco
    52,784
    congrats and welcome! how many miles on her? i understand want to cover all potential maintenance, but plugs aren't due until 120k. how many miles on her?
  9. HaiImBrian
    45
    Los Angeles
    The car has 120k miles on it and I understand it is that time for a maintenance job. It's a 2012 Clean title and I picked it up for 7900 off craigslist. I am pretty good with my cars so I actually plan on doing a full DIY maintenance overhaul.
    Right now.. the plan is
    • Spark plugs
    • Transaxle fluid change
    • Oil change
    • Brake fluid Flush
    • Coolant Flush
    Anything else I should add? About to close my amazon shopping cart =D
    thatoneraccoon and bisco like this.
  10. bisco
    52,784
    air and cabin filters, check/clean/replace.
    worth checking the brakes.
    pcv?
    thatoneraccoon and HaiImBrian like this.
  11. HaiImBrian
    45
    Los Angeles
    I'll definitely check the brakes and filters.
    What do I have to do with the PCV? Thank you for the info! I thought I did enough reading haha.
  12. bisco
    52,784
    nothing actually, if everything is working right. sometimes they get clogged.
  13. iamvietdang
    iamvietdang Member
    57
    60
    West Palm Beach
    Four Touring
    Inverter coolant, clean battery fan vent, and clean fuel injectors to name a few others.
    2016 Prius 4T Premium Convenience Pkg
    2016 NX200t F Sport
    thatoneraccoon, HaiImBrian and bisco like this.
  14. HaiImBrian
    45
    Los Angeles
    I'll be sure to check it out anyways! I just found some details on it.
    I'm actually confused now. There are two types of coolant right? The inverter coolant and the ICE coolant. Do both of these use the same type of fluid?
  15. iamvietdang
    iamvietdang Member
    57
    60
    West Palm Beach
    Four Touring
    Yes same coolant but separate systems.
    2016 NX200t F Sport
    HaiImBrian likes this.
  16. Mendel Leisk
    42,271
    @hailmbrian there's a good video regarding brake bleed. Same place. Must watch. I'll post some info later.
  17. HaiImBrian
    45
    Los Angeles
    Wow.. thank you everyone for help! These responses are amazing and I'm loving the community so far. I just bled the brakes on my 1999 toyota 4runner and hope the process is the same with a "hybrid" vehicle. I understand that prius have regenerative braking so I'm not sure if it makes a difference.
    I be using a motive power bleeder with DOT 3 fluid. This pressure bleeder shouldn't damage the regenerative braking system correct?
  18. Mendel Leisk
    42,271
    Without techstream software you need to put the car in "invalid mode" via a chicken dance involving brake pedal and shift positions. Then you can bleed per conventional car. Watch @NutzAboutBolts video (same place), and I'll post repair Manual info later.
    Fwiw I used syringe with thin tube extension (to baste fluid out of reservoir), tubing with bleed valve grommet at end, mayo jar with hole in lid, 8 and 10 mm wrench, and 2 pints Toyota dot 3.
    And some help from my wife, pushing brake pedal, per video.
    #18 Mendel Leisk, Feb 14, 2017
  19. bisco
    52,784
    when you're in the brakes, lubricate the caliper slide pins.
  20. Mendel Leisk
    42,271
    More info for brake bleed:
    Invalid Mode procedure, for brake bleed without techstream):
    set parking brake
    without foot on brake, press start button twice
    foot on brake, shift to Neutral
    press brake 8 times in 5 seconds
    push park button
    push park button
    (car should exhibit blinking brake symbol, indicating in "invalid mode", for brake bleeding without techstream)
    Bleed sequence:
    Front Right
    Front Left
    Rear Left
    Rear Right
    Note, watch the nutzaboutbolts video, to get a feel for bleeding front vs rear. Front brakes you have to be very careful, bleed in short spurts. The rears, assistant can just press-and-hold the brake pedal, pump activates, and pumps out lots of fluid.
    Make note of where fluid is in reservoir at the outset, and aim to end up at same level. Leave yourself a bit of fluid in reserve, for recheck a day or two later.
    Some brake info from Repair Manual attached:
    Soh, Robert Holt and m.wynn like this.
