2012 Prius Stabilizer bar end links exposed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by smallschumi, Jan 21, 2020.
  1. smallschumi
    smallschumi Junior Member
    42
    16
    I have 2012 Plug in with 180K miles. Just noticed that the stabilizer bar end links on driver side are exposed as the covering is torn. See attached photo. Haven't noticed any difference in ride quality.
    Is it safe to drive around for a while ? Have some long trips this month .
    Any upgrades recommended while I change the stabilizer bar
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Drive it til it makes noise
  3. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    You’ll need 2 of these, $50 total Moog K750043 Stabilizer Bar Link Kit
    Fostel likes this.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    Had the same issue on mine at 202K. Noticed the joints were loose during an inspection. Replaced mine with a pair of CTR’s from our local supplier.
    iPhone ? Pro
  5. Raytheeagle
    Raytheeagle Senior Member
    11,262
    15,507
    Bay Area, California
    2019 Prius Prime
    Your Quick Jack is showing:p.
    Links look in similar condition to the OP's though(y).
    Montgomery and m.wynn like this.
  6. The Critic
    3,193
    2,327
    CA
    Yes, my biggest waste of money...
    iPhone ? Pro
    Raytheeagle and m.wynn like this.
  7. iskoos
    iskoos Active Member
    402
    251
    Orlando, FL
    Had the same issue except all four end boots were torn in my case and they were causing terrible noise as the front swayed.
    Replaced them with the Moog (same ones as elementnomore showed above).
    Don't think of OEMs. They are unnecessarily expensive.
    elementnomore likes this.
  8. elementnomore
    136
    44
    Los Angeles
    be sure to grease before you install :)
  9. smallschumi
    42
    16
    Thank you all.
    No annoying sounds yet. Guess, I can wait for some more time to crawl under the car
  10. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    If it has sounds it’s bad if not it’s fine.
