2012 Prius Three 96,000 Miles, good deal?
Discussion in 'Gen 3 Prius Main Forum' started by kayceee, Jan 10, 2017.
  1. kayceee
    kayceee Junior Member
    Los Angeles
    Hi All,
    I'm looking at a 2012 Prius Three at 96,000 miles from a California franchise dealership (non-Toyota) for $10000. Clean Carfax, although there are no service records at any Toyota dealership.
    I'll be getting a pre-purchase inspection done at a Toyota dealership before finalizing the deal. Just wondering if anyone has advice on issues to look out for and whether this looks like a good deal or if I should target a better price?
    Thanks,
    Newbie
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    That is a good deal for a 2010, let alone a 2012. No service history at a dealership means the oil wasn't overfilled every oil change.
    My 2012 with 118k miles has no particular issues. So just check the standard used car things like leaking oil or signs of accident repair.
  3. working1
    working1 Active Member
    121
    112
  4. kayceee
    Los Angeles
    Thank you! Could you elaborate on "no service history at a dealership means the oil wasn't overfilled every oil change"? I though that no service history on Carfax just meant they took it to an independent mechanic?
  5. bisco
    52,875
    welcome!
    he just means, that dealers often overfill the oil.:cool:
    all the best!(y)
  6. kayceee
    Los Angeles
    Oh, thank you!
  7. kayceee
    Los Angeles
    Thank you, I will make a note to my PPI mechanic.
  8. mmmodem
    2,732
    1,703
    Bay Area, CA
    The first 6 oil changes I did were at the dealer and every one of them was overfilled. I started doing my own changes afterwards. So not having service history at the dealer isn't necessarily a bad thing. (Double negative, sorry:p)
  9. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I say buy buy buy!
    And overfilled per full line on diappstick is layperson terms. Ignore rookies. It's not an issue unless the rods are splashing and frothing the oil. Ignore what most say. Popular belief isn't right, it's just popular.
  10. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    An oil overfill is easily solved. Just get a syringe with a long hose attached to the end and now you have some top off oil for later.
    This also can be used as bonfire starter fluid.
  11. RyanM
    RyanM Member
    68
    40
    Wisconsin
    I think the dealers are told to overfill a little because these cars are known to consume oil. My toyota dealer does 10k oil change intervals although I prefer 5-7k myself. My next oil change I will be doing myself @ 7500. Full synthetic 0w20
  12. 08PriusXSJ
    08PriusXSJ Junior Member
    42
    Connecticut
    I just bought a 2008 Prius with $95400 miles for $3800. So far I drove about $1000 miles without any issue detected.
