2012 Prius three
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JamesLee, Apr 16, 2020.
  1. JamesLee
    JamesLee New Member
    Oregon
    Hello all, I have 2012 Prius with engine coolant loss. I have logged over 200k. Always done services at Toyota dealer. Recently I would add coolant a bit full and then a week or two later warning light comes up especially when going uphill on freeway. Then I would turn blast the heater to full and the light would go away. The coolant level dropped again and then I would add some more coolant. This has been going on for few months. My one gallon coolant bottle is almost empty now. I don't see any coolant leak on my driveway nor anywhere on the vehicle that I can see. I just changed the motor oil for the first time on my own and the used engine oil looked normal. Could this still be bad head gasket problem? My Prius runs perfectly otherwise. Any other possibilities? Thanks in advance.
    52,640
    i would say yes. try a leak down test
    pjksr02 likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Yes bad
    pjksr02 likes this.
