2012 Prius Two: trunk handle sensor
Discussion in 'Newbie Forum' started by BlackPrius2012, Apr 24, 2012.
  1. BlackPrius2012
    BlackPrius2012 New Member
    I am looking at the underbelly of the trunk handle and I see a rectangular padding on the left side and a flat area on the right. In the manual, there is a smallish round button on the right. My manual does not match the handle. What is up with that?
    Supposedly the round button, I think, locks all the doors, including the trunk door.
    Is this feature only on the fancier Prius'?
    :confused:
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    It sounds like you're referring to 3-door SKS (two front doors and the hatch). Prius Two has only 1-door SKS (driver's door only).
    One needs to go to model Three or above for 3-door SKS.
  3. Tideland Prius
    16,680
    Correct. 3-dr SKS is available on 2012 Three and higher.
  4. Betrock
    Betrock Junior Member
    22
    Tampabay Area
    RE: Prius 2011 Two- Hatchback
    Isn't the rear door supposed to open, when the flat area under handle is pressed, if you have the SKS on your person?
    Mine is a new car. Unless I'm doing something wrong, mine won't open - unless I press the Unlock button on the fob.
    Before I take it back to the dealer, I thought I'd ask if it was 'user' error!
    Thanks,
    Betrock
  5. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Only if you have 3 door smart key system. On the 2010-2011 Priuses, you needed to have model Four (aka IV on '10) or above to have 3 door SKS. For the '12s, it's model Three or above.
  6. Tideland Prius
    16,680
    What Cwerdna said. It'll only open if you have the 3-dr SKS which is available on model Three and higher. With the Two, only the driver's door has the Smart Entry and Touch Sensor lock.
  7. Betrock
    22
    Tampabay Area
    That's a relief! I thought something was wrong, which meant that other electrical things could be wrong, and there are so many electrical things! ....Lions & tigers & bears, Oh my!
