2012 Prius V ,ABS brake and traction light on, code C1391, denied by Toyota ZJB
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Amily, Nov 1, 2019.
  1. Amily
    Amily Junior Member
    17
    FL
    Mine is 2012 prius V has the same problem, got code is C1391. But when i went to the dealership, the service agent searched my Vin, and told me, even we would do the diagnostic and get the same code C1391, our car will still not by covered by the ZJB Phase 2 because this customer service program didn’t show up under my car’s information’s description. Then I called Toyota customer service, they also used VIN number to search and got the same answer.
    Update, did the diagnostic at toyota dealership, code C1391, but they refuse to cover the car by ZJB Phase 2, what i can do? really need suggestion. I can't understand i have the same problem, why they cant honor the warranty? Thanks,everyone.
  2. ChapmanF
    17,012
    Trouble codes give you some information about what is happening in the brake system, but they don't completely pin down why. The workup section for C1391 in the repair manual (more info) can give you some idea of the things that can cause that code.
    When a company announces a warranty extension for a certain issue, it usually means they have discovered a common underlying cause where a lot of the manufactured units will develop a certain symptom. For example, they might find their part supplier made a bad run of parts on a certain line in a certain month, and they know which cars those units went into.
    That doesn't mean that no other Prius ever made will ever show C1391 symptoms. Things do wear out. Normally that will be randomly spread out over a wide range of mileage, tailing out past the expected life of the car, and some unexpectedly early.
    But that doesn't mean an announced warranty extension is meant to cover everybody who ever has a part that wears out. It's usually limited to the parts that wear out because they were in a known run of parts with a specific known defect that was the reason for the announcement.
    Robert Holt likes this.
    50,849
    welcome!
    how many miles on your car?
    how much do they want to repair it?
  4. Amily
    Amily Junior Member
    17
    FL
    I don’t know if I should be covered by the ZJB program. I will attach the diagnostic report and parts need replaced.If More information needed, please let me know. 92000 miles.
  5. Amily
    Amily Junior Member
    17
    FL
    Thanks for reply. 92000miles, $4083 to fix it, I attached the diagnostic report and parts price.
  6. Amily
    Amily Junior Member
    17
    FL
    Thanks for your reply. My car is 92000mile, I bought it just 2 years ago. It is a CPO car when I bought it. I only drive 7000 miles a year. I attached the diagnostic report and parts quote.
  7. rjparker
    rjparker Tu Humilde Sirviente
    9,331
    5,691
    Texas Hill Country
    One thing to consider is obtaining the parts and finding an independent shop.
    For example:
    47070-12020 Booster Pump, your dealer $913, Mcgeorge online $696 or ebay used $164
    47050-47110 Master Cylinder, your dealer $1405, Mcgeorge online $1072
    Tim Jones likes this.
  8. Amily
    Amily Junior Member
    17
    FL
    My concern is should I covered by ZJB from my attachment? 7000 miles a year, a CPO car, I don’t expect $4000 repair just 2 years
  9. Amily
    Amily Junior Member
    17
    FL
    Or everyone think I should not be covered based my vin? Even the same problem not normal wear out
  10. rjparker
    9,331
    5,691
    Texas Hill Country
    Warranty extension programs are different from standard warranties as they don't apply to everyone with the same part, just those years and vins Toyota deems fit to cover. I might go to another Toyota dealer with the estimates and request they contact Toyota corp for help.
    I am sure you can appeal the decision while realizing the odds may not be in your favor.
    I think there are options to get it fixed for around $2000 if you wanted to do some online shopping along with first finding an independent mechanic that would take it on.
    Is the car driveable as is?
  11. bisco
    50,849
    try calling toyota corporate back, and explain the situation regarding cpo and the amount of miles.
    ask for some goodwill warranty consideration. perhaps they will help with the cost.
    i don't know any other way to find out if it is covered by the extended warranty except through the vin, that is how toyota does it.
    Mollyisadog likes this.
  12. ChapmanF
    17,012
    That's the question, whether it's the same problem, or normal wear out, or some other cause. If Toyota made a list of VINs for ZJB, presumably that means they knew of something specific to a specific run of parts that would make those more-than-normally likely to fail early in this way. But that doesn't mean that parts outside that run can never fail in any way that shows similar symptoms.
    92,000 miles seems on the early side, but probably not completely outside the bell curve of when somebody's part might go, out of millions of units on the road.
  13. mikefocke
    3,869
    1,744
    Sanford, NC
    What is the repair history of the car? Specifically, when was the brake fluid last changed?
    What were the CPO warranty limits in terms of months and miles and how does this car fit into those limits? When was it first put into service via a sale and first ownership change?
  14. Tim Jones
    Tim Jones Senior Member
    1,740
    562
    SE Texas
    2011 Nissan LEAF
    I bought both parts online today, used supposedly 76,000 miles.... $210.00 going to install myself.
  15. Brian Procopio
    Brian Procopio New Member
    Sarasota, FL
    Hello Tim,
    We just got a $3500 quote to replace the master cylinder and the booster at our local dealership. I would like to try to do this myself .
    Did it require special tools and how did it work out for you? Appreciate any feedback. Thank you Brian
  16. Tim Jones
    1,740
    562
    SE Texas
    2011 Nissan LEAF
    Haven't done it yet... was diagnosed with pneumonia this afternoon. I will keep you informed. I haven't had any codes just the running of the pump every 15 seconds.
    bisco and Brian Procopio like this.
  17. Brian Procopio
    Sarasota, FL
    HI Tim, Hope you feel better soon. Stay hydrated and res. I see that we can buy Toyota genuine parts for the master cylinder and the booster at a local dealer for just over $1400.00. This is interesting because the dealer that has my car said, " $2500 was the parts cost alone. It's interesting that they can sell the parts at a profit for $1400.00 at a different Toyota dealership. Possibly another member has done this job and could offer feedback on their experience?
  18. Tim Jones
    1,740
    562
    SE Texas
    2011 Nissan LEAF
    If your going to do it yourself I would use recycled parts. You can find both parts low miles parts you need for $400 or less.
  19. ChapmanF
    17,012
    What parts are you looking at?
    I just ask because in Gen 3 there's a nomenclature gotcha that can trip people up.
    The "booster" (without the word "pump") is a purely hydraulic part at the rear of the master cylinder, not available separately. There's just one part to buy that is all of: the "master cylinder", the "booster", the "actuator", and the "skid ECU". (At least on the Gen 3 liftback; they could have packaged things differently for the v.)
    So if somebody is showing you one price calling it the "master cylinder" and the "booster", that could be because it's the price of one part.
    There is another part that's known as the "booster pump" (don't leave out the second word!), also known as the "accumulator". Are you looking at pricing for both the master-cylinder/booster/actuator/ecu and the booster-pump/accumulator, or only for one of those assemblies?
  20. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I would talk with the service manager. Have them give you the codes and then argue the codes match since now they have added 2011-2015. find your built date which is on same sticker as the Tire pressure specs on your driver side. i attached the copy of the letter. take it to the manager. if they don't budge, i would look on ebay or LKQ. It shouldn't cost more than $400-500 in labor plus parts. Even though its fairly accessible, its very labor intensive. Also try finding local hybrid mechanics near you.
