2012 Prius v battery vent cleaning
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by dioworld, Dec 21, 2012.
  1. dioworld
    dioworld New Member
    I just got my prius and i notice there's a vent under the rear seat for the battery,
    I have a big german shepherd and his fur is everywhere in the back. I'm a little worry eventually his fur with clog the fan, I'm wondering if the prius has a battery vent filter or is there anyway to install one.
    thx
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is no filter and you do need to periodically clean out the vent/fan since you have a pet.
    JeffD
  3. dioworld
    dioworld New Member
    Thanks, is there any instructions on how to clean it? where is the fan located ?
  4. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
  5. Mendel Leisk
    42,354
    I have some vacuum cleaner motor filter material. Soon after purchase I started reading about this problem, so cut and fitted a peice in behind the filter inlet. Periodically I check it's condition with a strong light. It's picked up a small amount of lint and a seed or two. I would think it reduces air flow slightly, but seems ok.
