2012 Prius v doesn't start
Discussion in 'Prius v Main Forum' started by hoydenish, Feb 12, 2020.
  1. hoydenish
    hoydenish Junior Member
    I was going to start the car as usual this morning. My foot was on the brake, I press the power button, the dashboard showed all kinds of warning signs. The doesn't start. It only goes to neutral and the P position request light flashes and car beeps. I replaced the 12v battery and it didn't solve the problem. Any experience on this and what else I can try. Why does it act
  2. Air_Boss
    Air_Boss Senior Member
    4,248
    1,195
    New Yawk
    In my experience, this type of display is an artifact of a depleted 12V. Some load probably inadvertently left on overnight.
    Remove the replacement 12V, make sure it is fully charged, wait at least 15 minutes for any retained potential to dissipate, then reinstall the fully charged 12V.
    If that is unsuccessful, try the Emergency Start procedure explained in another similar thread.
    #2 Air_Boss, Feb 13, 2020
    52,804
    It is with considerable recommendation that the trouble codes be read with tech stream Toyota diagnostic software
  4. Mendel Leisk
    42,298
    Short of full-blown techstream, something like Dr Prius app and a carista bluetooth adapter will also read codes. Maybe not as complete, just rudimentary. Or a generic code reader.
  5. Air_Boss
    4,248
    1,195
    New Yawk
    PLX Kiwi Bluetooth mobile OBDII reader... $40
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I have the Kiwi2 and it works well:).
    It just doesn't pull what a J2534 protocol harness paired with tech stream does;).
    But good luck to the OP(y).
    Air_Boss likes this.
  7. Air_Boss
    4,248
    1,195
    New Yawk
    Poor man's factory diagnostics, and cross-platform capable!
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    unfortunately I have version 10 and now our cars are too new and in need to upgrade:cool:.
    From what I saw on version 13 it left a lot to be desired:(.
    But I'll figure it out as having techstream is the right tool to have for the DIY type(y).
    SFO likes this.
  9. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Might be the inverter.............
