2012 Prius v door
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by blend123, Sep 12, 2021.
  1. blend123
    blend123 Junior Member
    26
    Los Angeles
    I need to change my 2012 Prius v driver side door and wondering if a 2012 Prius door will fit? Are they the same / similar?
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Not even close.
  3. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    The Prius V has a longer wheelbase than regular Prius, so not even close is correct. The back door is significantly wider in the V, which is why Prius V's make great Taxi / Rideshare vehicles.
    Good news is, the Prius V has not changed from 2012 to 2017, so a Prius V door from another year is very likely to work. I suspect there are changes between trim levels as far as soundproofing, as my 2017 Prius V four sounds quieter when you close it, than my 2013 Prius V two.
