2012 Prius V Electrical Problems
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by blend123, Jun 25, 2024.
  1. blend123
    blend123 Junior Member
    26
    Los Angeles
    I washed my Prius today at a local car wash. I pressure washed inside the hood. I washed the car around 10am. The car was running for most of the day. It started with the left blinker not working. Then at about 8pm, I went to the store and the car started. Once I came out of the store and tried to start the car, the car would not start and all the lights in the dashboard were lit. Any ideas where to look? Do I let the car completely dry from the inside?
  2. Mendel Leisk
    42,345
    Checked the LA weather; you’re in luck on that front at least: leave it out in the sun. Have you got compressed air, or a leaf blower? Try to clear residual water as much as possible, as soon as possible. Disconnect and blow out every under-the-hood electrical connector you can manage.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,099
    6,966
    Texas Hill Country
    Verify your 12v first. If it’s good I would certainly blow dry the ecm area next to the fuse box.
