2012 Prius V engine noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by blend123, May 11, 2021.
  1. blend123
    blend123 Junior Member
    26
    Los Angeles
    2012 Prius V with 202,000 miles. Engine is making noise. The car runs and there are no engine codes. Any ideas of what it might be? I included a video of what the engine sounds like. Thanks!
  2. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    If it was the head gasket you would be low on antifreeze. And the engine runs terrible at startup then clears out.
    Have you checked the oil?
    Sounds like something in the valve train.
    blend123 likes this.
  3. blend123
    26
    Los Angeles
    It is low on coolant. I added coolant, and it slowly drains to low.
  4. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    is the engine running rough?
    I had a blown head gasket and it didn't sound anything like that but if your loosing water that almost always means the dreaded head gasket.
    But this sounds like more than the HG
    Maybe a bent connecting rod....
    I think your going to need a new motor.
    So sorry to see and hear this.... These engines can be pretty crappy.....Other should be responding soon.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Hey, I believe that's the sound I had one very cold morning. There's a T-SB-0027-16 for a sticking EGR probably what is making that noise. Description is MIL "ON" DTC P0401 and/or Rattle After Cold Soak. It is due to carbon build up. At 200k mi this is no longer covered I'm afraid.
    Part #s:
    04004-58137 EGR Valve Kit
    25685-37010 Gasket #1, EGR Cooler
    00451-00001 LBL Authorized Mod Label
    Need dealer/someone to flash the ECM (PCM).
    Just addressing the noise.
    moto g(7) power ?
  6. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
  7. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
  8. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
  9. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Tried to put a link here but won't work
  10. blend123
    26
    Los Angeles
    Is the link to the EGR Valve and Gasket kit?
  11. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Googled it and was on amazon.
    Do you have a Check Engine Light?
    Guess when you change the head gasket you can take the plugged EGR cooler off and clean it and the motorized egr valve....
    I can guarantee the cooler is plugged......
  12. blend123
    26
    Los Angeles
    Yes, I do have a check engine light on.
    P0607 control module performance
    P0171 Bank 1 System too lean
    P0037 heated Oxygen Sensor heater control 1
    P261C coolant pump circuit low
    P0A80 and replace hybrid battery pack
    Those are the codes that came up.
    Is the EGR cooler accessible only when replacing the head gasket?
  13. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Yo can take it and the intake manifold off. They are all plugged..... Would be the easiest when head job done.
    But I did all of mine long before it blew the head gasket.
  14. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    @blend123 I think EGR is on top not hard to get to.
    moto g(7) power ?
  15. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Egr motor and valve not bad but egr cooler a pretty big hassle
    jzchen likes this.
