2012 Prius V Engine replacement
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by blend123, Aug 29, 2021.
  1. blend123
    blend123 Junior Member
    26
    Los Angeles
    I replaced my engine. All seems to be good. However, the engine light is still on and it reads the same codes as the old engine. Does the dealer have to clear the codes? Do I have to change the ECM? Do I need special software in order for the engine light to go away?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,099
    6,966
    Texas Hill Country
    I would certainly clear the codes. Most scanners can do it. If they return you have an issue.
  3. blend123
    26
    Los Angeles
    I tried to with my Actron OBD but can't.
  4. rjparker
    11,099
    6,966
    Texas Hill Country
    What codes are there?
  5. ChapmanF
    19,020
    That would have been my 1st question. :)
  6. blend123
    26
    Los Angeles
    P0171, P0037, P261C, P0A80
    There's a new code that didn't appear before: P0607 - control module performance
  7. rjparker
    11,099
    6,966
    Texas Hill Country
    Not a good list. Sounds like coolant pump, o2 sensors and battery issues were not part of the engine swap. Particularly if they were there previously.
